Question about Sony STR-DG510 Receiver
Volume turned to MAX for almost no sound from record player
Ive connected my record player to the TV input since there's no input for a record player, but have to turn volume to max for any sound..
Anyone else have a record player plugged into this receiver, or a solution to this?
  • 218 Answers
You will need to purchase small box that converts your phono magnetic cartridge level output to a higher line input level before it goes into the TV input jack. Radio Shack used to sell a small amp for about $20 that was made just for that purpose and was called a stereo pre-amplifier and was model number SPA-50 and it plugged into the standard wall outlet to get power. Back in the "old" days when phono magnetic cartridges first became popular some of the older home stereos had only the ceramic phono style inputs (or an aux. input) which were about the same input level as a tape input or aux. input (or TV input) and so you would have to use one of these adapters to boost the newer magnetic cartridge signal up to the same level as a ceramic cartridge in order to use a new style of phono. This will fix your problem if you can find one at Radio Shack or some other place, perhaps on the internet. Hope this helps you.
Posted on Nov 21, 2007
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Different volumes on different inputs When I'm
Some TV's have sound adjustment settings for outputs such as HDMI. It might be turned down. If you have an optical connections on both TV and sound system you will get better sound with that.
Jan 24, 2018 | Yamaha HTR-5740 Receiver
The unit is connected to a TV via HDMI lead. I am trying to record from an LP record player to dvd via the front connection of the dvd recorder, it is recording but at very low volume?
You need a phono pre amp between the Recorder and LP. The audio out put of LP player is very low. that why the volume is very low. You should amplify it using a phono pre amp and then connect to the recorder's input.
Aug 10, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a dell xps 400 with front and rear
Mar 21, 2010 | Dell Dimension XPS PC Desktop
Does an mp3 player put out enough power for input to KAC-624 amp?
Have you connected the rca plugs to the radio or amp directly? If you've connected it to the radio make sure that the input level controls are adjusted AND available on that model (it will say AUX, INPUT, SUBWOOFER, REAR, etc.) Connecting your mp3 player directly to the amp will not have enough juice to hear sound you need to connect it to the radio first.
Oct 02, 2009 | Kenwood Car Audio & Video
Very low output volume from Presonus Firebox recordings
i do'nt know the name of the sound driver installed in my PC
Jun 30, 2009 | PreSonus Firebox 6x10 External Sound...
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony STR-DG510 Receiver Logo
227 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
