Question about Dishwashers
My Danby DDW2406BLS dishwasher have the water level is too low and the upper sprayer don't turn with the water pressure. whose the problem, my water inlet is good
  • 44 Answers
Check grease trap [plastic] and strainer on pump with m/c off.you have to take off side and front panels to do this.disconnect electrical power first.!
Posted on Jul 21, 2009
Wirl pool dishwasher is not cleaning top rack does not get enought pressure
Do you have multiple sprayers or only sprayer for water on the lowest level? If this is the case (only lowest level sprayers), look at how you're loading the bottom rack. If you are putting items that would stop the sprayers, like mixing bowls or casserole pans, that would be stopping the sprayers from hitting the top tier item.
May 23, 2012 | Dishwashers
Whirlpool adp252 not rinsing clean
Hello
Clean the internal parts of the dishwasher. Use a clean wet cloth and wipe down the inside including the racks and the sprayer arms. Remove the upper arm by unscrewing the center bolt. Clean both sides before replacing.
Check the water pressure. The dishwasher requires inlet water pressure between 20 to 120 psi. If the water pressure in the line is too low, proper rinsing will not occur.
Check the water temperature. The dishwasher performs at optimal levels with 120 degree water. Check the hot water heater for needed adjustment.
Use the right detergent. The dishwasher requires detergent designed specifically for dishwashers. Other detergents will leave spots, residue or food on dishes.
Set the machine to the proper cycle. The dishwasher offers a variety of cleaning cycles. Select the appropriate cycle for the type of cleaning required.
Load the dishwasher properly. An overloaded machine will result in dishes not being cleaned thoroughly.
Sep 12, 2011 | Dishwashers
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Kenmore ultra wash dishwasher has not enough water presure to turn the upper level water jets. Any sugestions?
Remove the sprayer and clean the spray nozzles...they are probably clogged with dirt and excessive dishwashing soap. Mine actually had small chips of my plates in it!
Dec 17, 2010 | Kenmore Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Danby Designer Dishwasher sprayer arm stopped working
is anything in the way of the arm? Sometimes you can't see an item sticking down too low ... interfering with the spinning.
Oct 05, 2009 | Danby DDW1805W Designer Series...
Whirlpool dishwasher low water presure upper level
Since you have low pressure
  • Check the float switch inside the tub, it should move freely up and down.
  • Check the harness to the motor
  • Check start capacitor on the left side of the wash motor
Jan 31, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Feb 15, 2008 | Dishwashers
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
221 people viewed this question
Top Dishwashers Experts
