Question about Briggs & Stratton Garden
Pressure washer hesitates, does not start. Unable
Pressure washer hesitates, does not start. Unable to pull recoil after many attempts to start.
  • 47 Answers
Get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Posted on Jul 21, 2009
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Problems with recoil starter
The recoil starter needs to be repaired. It is a common failure item.
Apr 27, 2014 | Craftsman 3000 PSI 27 GPM Briggs ...
Pressure washer not starting
Can you turn the motor over by sticking your fingers under the recoil and move it freely. If not something is locked up, either the motor itself of the pressure pump. Remove recoil and see if you can turn over by hand
Apr 22, 2013 | Garden
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Apr 23, 2010 | Honda Karcher G4000RH Pressure Washer
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
The cord we pull to start the washer machine is stuck
So it's stuck out? If so loosen the recoil assy's bolts and it will snap back once it's loose enough. This usually happen due to bent recoil cover, swelling of the pull rope, or too much pull rope in the recoil (length).
Or it stuck in and won't pull over. If so remove the spark plug and see if it will pull. Keep away from the spark plug oil since if the unit is flooded with fuel or oil it will shoot out of the hole and cover you with it. If it does not pull over without the spark plug in, there is a 90% chance your motor is blown.
Let me know what you find
Mar 30, 2009 | Northstar Pressure Washer Trigger Spray...
Honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Mar 22, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
394 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
