Question about IBM ThinkPad T41 Notebook
Key come off keyboard
my n key has come off. how do i get it back on?
there are 2 white hooks and a black bar - they seem ok.
  • 27 Answers
Hello Tom,
I believe you just place the key on and gently press down.
Posted on Dec 03, 2007
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
Jan 16, 2013 | Computers & Internet
Trying to toggle from blue keys to white keys
You have to hold the shift key down and then hit the question mark key.
In the picture above the key is white but most of them are black. There are 2 shift keys at either ends of the keyboard with the trade mark up arrows on them.
Feb 24, 2010 | Acer Computers & Internet
Can't get the @ symbol on a HP mini 110-1033ca
To the right of the keyboard is the 'ALT GR' ("alternate graphic") key.
Hold that key down, and press the '@' key.
Dec 31, 2009 | HP D8597A Keyboard
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
My shift key came off and i can't get it back on
Normally the metal bar is used as retention in order to elevate the key after it has been used.
Commonly, the metal bar should be taken out, attached to the key itself. When re attaching, the metal bar should have plastic brackets on the keyboard where the metal bar must be placed into. It's tricky, but 3 to 5 tries usually solves the problem for me.
Hope this helps
Oct 31, 2009 | Computers & Internet
Yamaha PSR 510 -- one of the white keys broke out. Need HELP!
I figured it out. Once the whole 61-key section is unscrewed (I believe its just one screw at the end and it simply lifts off) you have to take a flat head screwdriver and stick it in the top edge of the key rows and twist to force the little tabs out of the slots. Be careful because this is not easy and some of the little tabs might break off - it may not be crucial for the keys to snap back in, though. The first few black keys and the tab above are all one solid piece of plastic. All of the keys are grouped in groups of 3-5 or so as one piece. White keys are layered under the black keys so you must release black key groups to access the white key groups. Once you have forced a key group lose from its snap attachment you must also free the keys from underneath to fully lift the keys off the unit. You have to BREAK the hook shapes found on the underside of the keys (they rest up against the orange rubber lining.) Take wire cutters and snap off all the tips in the key group you wish to remove. Depress a key and watch the movement underneath if you have trouble seeing what I'm talking about - you will see the hooks - think of it as the bottom of the key because that is what it is. The piece you break off should be very small - just enough to remove the hook shape enabling you to lift the keys right out. This will not cause the keyboard to be unusable. It will only make it possible to bend the key up once everything is reassembled. It is the only way I see to free the keys and gain access to the action underneath. As for that...
The action underneath is made up of a pair of rubber cups that when pushed make contact with metal sensors. These rubber cups can tear causing them to fail to pop back up to rest position. I am trying crazy glue to see if this will repair the tear. If not then I will try double-sided tape so that the plastic key will pull the rubber cup back up with it (I hope) when released. Good luck. It is a great keyboard. Very sad to see it discontinued.
This is regarding the Yamaha PSR-510.
Feb 10, 2009 | Yamaha Full-Size Keyboard
0 and - keys fell out!!!!
This could be a little difficult to explain.. coz the white ring acts as a spring and putting it back on is not hard but difficult to explain.
See first of all on an acer laptop a key has 3 components
the key
the white thing (which holds the key in place)
and a black soft thingy (which actually gets pressed wen u press a button and acts like a spring)
first of all the white ring can be removed and refixed easily .
Youll see 4 small hook like structures on the palce where key needs to be placed ... first place the white ring over there, the white ring has 2 things which come into one another. (try referring to the key where in the white ring is still in place).
now if the black spring like thingy is removed from its place, place it in the center of the ring and put the key on, try moving the key a little, if the key and white ring are put correctly, this will produce a click like sound showing the key is locked by the white ring .. if the white ring is dismantled into 2 parts it could be a little tricky to put them back on.. in that case i guess ull have to check a fixed ring and try and replicate the same for this key
for further assistance feel free to mail me on:
Aug 27, 2008 | Acer NSK8458AN Keyboard
Hp presario c500 laptop
You're best bet for this is Ebay. There are several vendors that sell individual keys and retainers. You might also look into a whole keyboard, many times you can get a keyboard for a fairly cheap price, and you'll have many replacements for the future.
Jul 03, 2008 | HP Compaq Presario C500t Notebook
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Some wrong symbls on some keys!?
did u hit teh fn key to change it back
Nov 21, 2007 | Compaq Keyboard
IBM ThinkPad T41 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
