Question about Dayton Permanent Split Capacitor Motor Fan
Internal wiring I have a Dayton 2 HP pump motor Model # 9K653. The field winding wires were unplugged from the L1, L2, L3, L4 connection points. I am trying to run this motor on 220V (is rated to do so). Can you tell me where the winding wires go?
  • 12,061 Answers
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
Previously hard wired. How do I connect a power cord?
It doesn't really matter which wire goes to L1 L2 or L3. All that can happen is it will run in the wrong direction. If it does just interchange any 2 of the L1 to L3 connections and this will reverse the motor.
Dec 08, 2015 | Hobart D300 Stand Mixer
Wiring diagram for Dayton IKRT9 portable electric heater
Sounds like it's the on/off switch.
what colour are they. . Usually one is the power supply to the switch and the other will be the return from the switch to the load.
Check these wires with with a multi meter.
Jan 06, 2014 | Kitchen Ranges
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
We have IR SSR 150HP compressor, where when starting alarm display "check motor rotation" we already change the phase L1, L2, L3 but this alarm still appear. what should we do?
to change rotaion on a three phase motor just which 2 leads.
Change L1 to the wire now on L2 and take the wire on L2 and move it to L1. the rotation will now change. or L2 and L3... just two wires
Nov 24, 2010 | Ingersoll Rand Stationary Air Cooled...
Need to rewire from 480 to 240 need coolant pump diagram for colchester # 348337 3 phase motor
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Jun 22, 2010 | Measuring Tools & Sensors
How do i wire pressure switch 034-0195
Just put in series after the switch before the wirings
go to the electric motor. Put the two electrical wires
to L1 and L2 (Line In). L1 must be with normally closed ontact L3 while L2 must be with L4. (L3 and L4 - is Line out) for the motor terminal wires. Before connecting wires at L3 and L4, Check for continuity at L3 and L4. Set the muti tester at 1 x 10 Ohms..Then put the multi tester probe on it. The reading must be infinity or no reading at all. Then
connect the motor wires at L3 and L4.
Oct 30, 2009 | Air Tools & Compressors
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
I am looking to use the stat feature on my calc, can you assist ?
Assuming you already have L1 and L2 stored:
2ND L1 ^ 2 STO> 2ND L3 ENTER
2ND L2 ^ 2 STO> 2ND L4 ENTER
Jan 12, 2009 | Texas Instruments TI-84 Plus Calculator
Dayton 1/2 hp dual voltage motor overheats (mtr #6k79). Replaced original motor with same motor overheats in 10 -30 minutes. White lead to #4 terminal, black lead to #1 terminal, ground to casing.
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Jul 23, 2008 | Dayton Heating & Cooling
Dayton Permanent Split Capacitor Motor Fan Logo
763 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
