Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Change the v-best on a craftsman 42' mower 6 speed transaxle lawn
How do I change the v-best on a craftsman 42' mower 6 speed transaxle lawn tractor?? model # 917.256522 15.5 HP IC electric start
  • 130 Answers
If your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
FYI I have a Craftsman LT1000 18HP twin opposed Briggs with a Peerless transaxle 206-545c 6 speed manual trans (not the Hydrostatic). I was given this Lawn tractor by a friend who took real good care of it. runs starts great but it started binding in 3rd gear and was very hard to get it out.of gear so by pushing the cluch/brake in and out manytimes and forcing forward into 4,5,6 gears I was able to get it out of 3rd.
Iam a mechanic and have over 30 years experience.so I decided to research the Peerless 206-545c transmission I found some great info online and helpful repair vids on youtube. I decided to post here to try and help people that are having the same issue with this trans. after I got the tractor in the garage I noticed the left rear wheel was wet on the inside with gear oil.so I decided to do a rebuild.after learning about this transmission.I went to sears parts direct.com and put in my craftsman mower model number and it came up with a exploded view of the tecumseh\peerless 206-545c. on the diagram. I found the 2 transaxle seals needed item# 157 and for like 15 bucks ordered them. you can order all the seals if you choose.
I realized that there is a fill PLUG ONLY and no drain plug on the bottom of transmission.you must take this transmission out of the tractor and lay it upside down in a oil catch pan and drain the fluid out. you must open the transmission all the way to replace the transaxle seals.Im told that most lawn tractors of today have disposable transmissions.another words they dont want you to fix them youreself they want you to bring it in so they can charge you to diagnose it and say yep you need a new transmission. lol thats why no drain plug.so if youre not a mechanic you gonna be payin boy..
I did find alot of BAD info in doing research on this transmission online ie: people posted wrong info saying that you just have to loosen all bolts on the trans case and you can put new seals in... VERY WRONG and the other wrong info was the amount of gear oil. the correct amount of 80w90w is 32oz 2/3 full from top(use a dowl or straw to measure. I use LUCAS high Performance. gear oil. I included a Tecumseh/Peerless link for you to check out. http://www.smallenginesuppliers.com/html/engine- specs/tecumseh/Tecumseh_Transaxle_Service_Information.pdf scroll down to MST 200 series trans find the 206 545c documentation and it tells you every thing you need to know about the 206-545c ie 90/100 inch pounds when torqing bolts on case. shifting adjustment (ball hex screw adjustment) 1 full turn after flush with housing.etc. I was able to save this transmission I opened it up and cleaned every gear by hand with Seafoam trans cleaner and put it all back together using permatex (GEAR OIL GASKET MAKER) and waa laa it shifts amazing and no more leaking from axle seal. I get no benefit from posting this just want other people to have the correct info and for around 40 bucks you can recondition this trans.if you open it up and find broken gear or gears go to ebay or sears and get parts which ever fits your buget.it took about 6 hours total to de install transmission and clean gears and put new seals and re install back into the tractor. just to give you a time frame. if you dont have time to rebuild it go to ebay there are used complete transmissions there but I would rather know what I have by doing it myself than buying used that may have the same issue and cost ya 200 bucks.
god speed bruthas
Posted on Jun 29, 2015
Wizard 42" (Craftsman) lawn tractor transmision locked. Belt smokes. 6 speed transaxle
if the trany is locked up u will have to remove the trany
most the time its the needle bearings on the input shaft
there 10-15$ each takes 2
but trany has to come aparts
they are fairly easy to open n fix them
Sep 14, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower wont engage in gear
@the rear of the tractor bottom left you'll see a metalrod sticking out and if it hasn't come off a decal with a picture of man pushing tractor that's it.
Apr 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Gear selector
SOUNDS LIKE THE BELT HAS CAME OFF OR THE PULLEY HAS BROKE
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need a free manual for a Craftsman 15.5 CI,
Go to the sears web site, then go to parts section, then to owners manual section. Type in model and serial number. Then you can download the manual for free.
Apr 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
918 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
