Pc powers up but will not boot
When i turn my computer on it will start but will not boot,all it does is just run,was told it is a software problem but not how to fix it.sure could use some help.
    President:
  • 1,383 Answers
When you power up the computer press F2 or "del" key to enter in bios.
Then load optimal defaults settings .
Aslo check your hardisk is detected or not.
Then start again computer press F8 key then enter in safe mode. then uninstall program or driver which you are installed and after that you face problem.
Open cpu cabinet Refix RAM memory.
Clean dust from mother bord circuit.
Reconnect power cable and IDE or SATA cable to harddisk.
Then check.
Thanks for using fixya.
Please rate this solution if it helps
Posted on Jul 21, 2009
Computer doesn't reboot after turning off.
You could have a power supply problem. Start up is ******* a ps until it is fully up an running. You may have bulged caps in the power so that takes awhile to full charge up. I would start there. No other reason for it to do that because it runs fine after it gets started.
Jul 21, 2017 | Computers & Internet
My computer turns on by itself and does not display anything
disconnect the power adapter and battery
2) make a HARD RESET 3) press the button power and hold by 60 seconds.
3) connect the power adapt +battery and try again.
4) if the problem persist. test the power adapter for short and repair or replace.
restart pressing the f8 and go safe mode with network, and RUN the scannow.
5) Run the software coming with the computer.too
God bless you
Mar 25, 2013 | HP Pavilion a264w PC Desktop
0xc000014c
A recent hardware or software change might be the cause. To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings, and then click "Next."
3. Click "Repair your computer."
If you do not have this disc, contact your system administator or computer manufacturer for assistance.
File: \Windows\system32\config\system
Status: 0xc000014c
Info: Windows failed to load because the system registry file is missing, or corrupt.
She did not have a Vista CD, as her PC came with it on, so I told her I would try my CD, I put in the CD and the same screen came up and would not change.
So I change the boot order, to start with CD/DVD first and still no change, it still starts up with that same screen.
So I copied the Vista CD to my memory stick and changed the boot order to run with USB first and no joy again.
I have run the boot in all of these orders with no joy:
CD/DVD
USB
Hard drive
USB
CD/DVD
Hard drive
Hard drive
CD/DVD
USB
Cheers,
Robin
Apr 27, 2012 | Sony VAIO Notebook PC VGN-NS235J/W
My HP Compaq Presario SR2170NX starts up but won't load
  • Make sure you computer is powered off
  • Turn your computer on and start hitting the F8 key
  • An Advanced Boot Menu will come up with an option to boot into safe mode
Restore your PC to the date when its performance was good.
Use a system utility software like RegInOut to fix this issue.
Hope it works for you.
Dec 26, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
My lap top turn on go to windows then shuts down and turns back on
try to turn off the laptop and then remove cables & battery on it. Then press and hold the power button for 8 secs ryanpajaro20_15.jpg
Then, reinsert the cables and battery on it. And then turn it on, check if you still have the same problem. If symptom persist, consult your PC technician on it...
Apr 13, 2011 | Gateway M305CRV Notebook
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Cannot sign on my computer getting message windows could not start following is missing or corrupt <windows root>\system 32\ ntoskrnt.exe. reinstall a copy i dont have any of the...
If computer does not boot into Windows, turn on the power and press f8 . On the Windows Advanced Boot Option screen, select one or more of the following options. Select them one at a time and press the enter key to attempt a system restart.
  • Disable automatic restart on system failure to view error messages.
  • Repair Your Computer allowsUninstall recently installed software programs Windows to run diagnostic tests.
  • Last Known Good Configuration (Advanced) to return settings to an earlier point in time.
  • Boot into Safe Mode and then Uninstall recently installed software programs . When in the computer is running in the Safe mode, click Start , Control Panel , and select the Uninstall a program option. When the computer is operating again, go to program manufacturer's web site for support information.
In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer. If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows.
Nov 11, 2010 | HP Compaq Business Desktop d220 Microtower...
My Toshiba laptop is very slow at booting up. I have been told that it is because I have approx 130 programs in my start up folder. However, short of turning one off and then rebooting for each...
For that go to start menu->run or press windows key + R key so you can see run type in "msconfig" then press enter then you can see system configuration utility click on last tab startup and disable all thewn apply and restart then all startup disable. If you want to uninstall any software for that go to start menu->control panel->add remove programs then uninstall software from there as you want . Also follow below procedure to speedup the computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here .Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Toshiba Computers & Internet
Error when trying to reinstall Dell Vostro 1500 Computer Software
Maybe you haven't removed your virus completely, some viruses (like Brontok.B/Worm ) disable some administrative features, and unable you to install new software...
So, if you can't remove the virus, do a fresh install of Windows ... Of course, which came with your laptop. Or I you aren't sure how to do that, call someone with a bit more experience. It's not a big deal .
Regards
Darko, Serbia
Mar 19, 2009 | Dell Vostro 1400 Notebook
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
