Question about SanDisk Sansa e250 MP3 Player
Sansa wont cut on when i press the power button,
Last thing it did before it cut off was acting up, flashing the connecting thing
  • 34 Answers
That could be for a large number of problems - either internal damage from water or being dropped, a completely dead battery, a batt that wont charge, or the software is caput. The only way you can fix it is to have it repaired or refurbished. Hope you have a warranty.
Posted on Jul 22, 2009
How do I get My e260 in recovery mode, it wont even come on?
1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. I do not think your model supports the recovery mode but you can try. 1. Press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa e260 MP3 Player
Blank Screen, Frozen, restarts FAT Error message
hold switch up for 15 seconds, this will reset the dam thing
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
F..ked up
Try a different USB cable and different USB ports. Lots of times it's the cable.
Try holding the power button "UP" for 15 seconds, wait a few moments, try turning on and off then reconnect to computer. This resets the unit.
Force MSC mode - power button "DOWN" in hold (orange showing), press and hold CENTER button while connecting USB cable (& don't release CENTER button until unit is recognized). You won't be able to transfer DRM-protected content but it might just fix what's ailing you.
Hope this helps.
Jan 06, 2009 | SanDisk Sansa e260 MP3 Player
Sansa express mp3 player
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful to push it in slow) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Feb 25, 2008 | SanDisk Sansa MP3 Player
Sansa E250 wont properly turn on
Hey .. I have a solution for this.. download pp5022.mi4 and sansa.fmt from the link
http://rs109.rapidshare.com/files/29178834/Sandisk_Sansa_R_Series_Recovery.exe
unzip these files and connect your sansa to the PC in recovery mode. You will find a 16mb drive opened and add these unzipped files into that drive and disconnect sansa from the PC. It will refresh and recover to the normal state.
By the way, to go to recovery mode press and hold the power button until the player turns off. Then switch it to locked state by switching the button at the top. Then press and hold the record button on the left and press the power button. Do all this after connecting the device to your PC. Good Luck.
Feb 18, 2008 | SanDisk Sansa e250 MP3 Player
My scandisk sansa clip mp3 player is fozen at the refresh database screen
I actually called the 800 sandisk number and the guy was helpful (after some annoying personal questions).
Unplug from your computer
Turn off the device.
Push the button down to be in the "Hold" position
Press down on the "center" button (inside the circle)
While still pressing on the center, plug in the device.
Now you should be able to see the device under "My Computer"
Right click on it and FORMAT --YOU WILL LOSE ANYTHING THAT WAS ON IT! But you will be able to use it again. I was assuming all my stuff was gone, it was just copies from my computer anyway.
This worked for me and now I just have put my music back on it.
Hope this helps everyone else! And don't hook it up to a MAC!! Even just to charge it!
Feb 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
It wont turn on
Hi. Try this and I hope it helps: Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully.
Apr 17, 2007 | SanDisk Sansa e260 MP3 Player
Snasa e260 wont load up
Hi. Your Sansa E260 might be encountering some system errors and would need a Firmware re-flash by setting it to its recovery mode. Try this: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again. I hope this helps. The E260 is a great player.
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
144 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
