Question about Whirlpool GH5184XPQ Microwave Oven
Whirlpool gold GH5185XPS not heating food
Our Whirlpool microwave has stopped heating and I am looking for someone to help me give an estimate of the repair, so that we can decide if its worth fixing it. Below are some more details.
Brand: Whirlpool Gold Accuwave
Model:- GH5184XPS
Old: - 3 years
The microwave seems to be on like normal [fan, light, turntable, controls etc..], but does not heat. I had heard a tripping sound yesterday while heating the food and also smelled some burning.
Appreciate your help. Thank You!
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool Gold Microwave Mod#GH7155XHS-1
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool Gold Microwave turntable will
Does yours have a feature which allows you to turn off the turntable with the control panel?
If not, you can see and hear a video of how a turntable motor should sound when you rotate it by hand.
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Posted on Jun 22, 2009
SOURCE: whirlpool gold accuwave system above the range microwave
minimum allowable height from gas cooktop to bottom of microwave
Posted on Dec 31, 2009
CCLOWAS
  • 13 Answers
SOURCE: Loss of power to Whirlpool over the stove AccuWave
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Posted on Mar 07, 2010
My whirlpool Max microwave has stopped heating up the food. How can I fix it ?
Does the microwave turn on, the plate spins and it counts down time?
If so, and the only issue is that the microwave is not heating you are looking at a High Voltage transformer or a Magnetron. Either parts should only be installed by a service technician, and will cost you $100+ for the repair at most repair shops.
Apr 27, 2015 | Whirlpool Microwave Ovens
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
Sep 02, 2014 | Whirlpool Microwave Ovens
My whirlpool gold GT4185SKQ-2 microwave won't heat
It's not door switch. It's the microwaves are not being produced. Do to safety issues DO NOT take apart. Replace
Jul 24, 2014 | Whirlpool Microwave Ovens
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Whirlpool GH5184XPQ Microwave Oven Logo
116 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
