Brand new LT, I can't get past the opening screen log in. I guess I forgot the password. I've read about the password reset disk. Tried to made one-can't figure out how to do it. How do I get into it? Arghhhhh
  • bemer5 Jul 21, 2009
    Ihave a Toshiba Sat M305-S4940-Vista Home Prem-locked out
  • bemer5 Jul 29, 2009
    yes
  1. Click on the start orb. Write down your username (the name listed right below your picture on the start menu).
  2. Place your Windows Installation DVD into your DVD drive
  3. Restart your computer
  4. When prompted, press a key on your keyboard to boot from the DVD
  5. Select your language options and click Next
  6. Select the option at the bottom to repair your computer
  7. Select your Windows installation from the list. Make sure you notate what drive letter it is installed on.
  8. Select the last option from the list to open a Command Prompt
  9. Type the following command, and press enter: regedit
  10. On the left, click on HKEY_LOCAL_MACHINE
  11. Click the File menu at the top, and then click Load Hive
  12. Click the option on the left to go to "computer"
  13. Double-click on the drive that Windows is installed on (you wrote this drive letter down in step 7)
  14. Double-click on the folder called Windows
  15. Double-click on the folder called System32
  16. Double-click on the folder called Config
  17. Click on the file called SAM and click Open
  18. Type "Target SAM" into the box and click OK
  19. Expand the HKEY_LOCAL_MACHINE folder by clicking on the triangle next to it
  20. Expand the Target SAM folder by clicking on the triangle next to it
  21. Expand the SAM folder by clicking on the triangle next to it
  22. Expand the Domains folder by clicking on the triangle next to it
  23. Expand the Accounts folder by clicking on the triangle next to it
  24. Expand the Users folder by clicking on the triangle next to it
  25. Click on the folder named 000001F4
  26. Double-click the item in the right called "F"
  27. You are now presented with an editor. You will see two columns: a list of letters and numbers grouped in pairs on the left, with a list of symbols on the right. We will only be using the list of letters and numbers on the left.
  28. Find the spot in the left column that says "11".
  29. Click to the immediate right of the 11, so that the flashing insertion line is to the immediate right of 11
  30. Press backspace to make the 11 disappear
  31. Using the keyboard, type the number 10This should change the information in the left column from
    02,00,01,00,00,00,00,00,80,8c,d7,b2,e9,97,c7,01,00,00,00,00,00,00,00, 00,1f,ea,fd,ad,e9,97,c7,01,00,00,00,00,00,00,00,00,de,ad,60,9b,e9,97, c7,01,f4,01,00,00,01,02,00,00,11, ...
    TO:
    02,00,01,00,00,00,00,00,80,8c,d7,b2,e9,97,c7,01,00,00,00,00,00,00,00, 00,1f,ea,fd,ad,e9,97,c7,01,00,00,00,00,00,00,00,00,de,ad,60,9b,e9,97, c7,01,f4,01,00,00,01,02,00,00,10, ...
  32. Click OK
  33. Close regedit
  34. Close the command prompt window and click on the 'Restart' button on the window that gives you the list of options.
  35. When your computer restarts, log in with the account named 'Administrator'. Use this emergency Administrator account to fix your normal administrator account by using the user accounts control panel
    If you do not have an installation disk, there are free password recovery
    procedures on the internet, I usually do not recommend these simply because
    they require advanced computer skills and some of them can turn your
    computer into an expensive doorstop.
    As a last resort, there is software available that you can purchase that
    will solve the problem, easily.
    The program that I recommend is the first one, it is very easy to create a
    recovery disk that you can use on any Windows PC. These recovery programs
    usually cost about $30 to $40 USD.
    Click on this link to learn more:
    http://www.password-changer.com/
Posted on Jul 21, 2009
  • Anonymous Jul 21, 2009
    Here's How To Create A Windows Vista reset disc:
    1. Click on Start and then Control Panel.
    2. Click on the User Accounts and Family Safety link.
      Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the User Accounts icon and proceed to Step 4.
    3. Click on the User Accounts link.
    4. In the task pane on the left, click the Create a password reset disk link.
    5. When the Forgotten Password Wizard window appears, click Next
      Note: You will need some kind of portable media before being able to create a password reset disk. This means that you will need a flash drive or a floppy disk drive and blank floppy disk.
    6. In the I want to create a password key disk in the following drive: drop down box, choose the portable media drive to create a password reset disk on.
      Click Next to continue.
    7. With the disk or other media still in the drive, enter your current account password in the text box and click Next.
    8. Windows Vista will now create the password reset disk on your chosen media.
      When the progress indicator shows 100% complete, click Next and then click Finish in the next window.
    9. You can now remove the flash drive or floppy disk from your computer.
      Label the disk "Password Reset" and store it in a safe place.
    Genius:
  • 1,043 Answers
Here are a couple of URL's that might help you out:
http://www.petri.co.il/forgot_administrator_password.htm
http://www.wikihow.com/Recover-a-Forgotten-XP-Password
http://pubs.logicalexpressions.com/pub0009/LPMArticle.asp?ID=305
http://home.eunet.no/~pnordahl/ntpasswd/
You did not mention which O/S you were using, but all of these sites are for Windows. If you are using a different O/S then I apologize for the sites. Some of them mention software to buy. If you are familiar with Bit Torrent then you can find them all there. Good luck, and I hope that this information will help you.
How to log into Dell Windows 7 computer forgot admin password?
Forgot Dell administrator password? Couldn't log on to Windows 7? It's really frustrated thing if Dell computer is locked since that happens. But even though, we can still find other ways to reset Windows 7 admin password without reset disk.
One: Reset Windows 7 admin password with Chntpw
The followings are the main steps to use Chntpw to reset Windows 7 forgotten admin password.
1. Get Chntpw and create a CD Windows password reset disk with it on available computer.
Besides Chntpw, iSunshare Windows Password Genius is another effective tool for creating Windows password reset disk.
2. Set your locked computer boot from CD-ROM.
When power on the computer, enter BIOS settings, choose BOOT option, and select CD-ROM as the first boot device.
3. Reset Windows 7 password to be blank
3.1 Select the partition where Windows was installed on
3.2 Select path and registry files
3.3 Select which part of registry to load, use predefined choices.
3.4 Edit user data and passwords, and select a user to reset its password. There is one simple choice - clear (blank) user password. Choose it and clear administrator password to blank instantly.
When successfully clear out the administrator password, quit out and press Ctrl + Alt + Del to restart computer, logging in to Dell Windows 7 computer without password.
More introduction details are here.
http://www.isunshare.com/windows-7-password/how-to-reset-your-windows-password-without-an-install-cd.html
Two: Reset Windows 7 password with Offline NT Password Registry Editor
Besides Chntpw, you can create a live cd or bootable usb with Offline NT Password Registry Editor which is a freeware program. It is based on the text console, so it may be a little difficult to carry out.
Here are the main steps to use Offline NT password registry editor:
<1> Get Offline NT Password Registry Editor and use it to create a live cd or bootable USB disk.
<2> Set your dell computer to boot with the USB
<3> Follow the Windows 7 password reset instruction to finish the operation when the password reset program starts.
Do you want to find more ways to reset Windows password without reset disk, please read this article:
http://www.slideshare.net/Clarafeng/lost-windowspassswordnoresetdisk
Sep 10, 2013 | Dell Computers & Internet
Forgot my windows log in password
If you have forgotten Windows login password then you can reset it by using windows password reset disk. If you don't have password reset disk then you can use stellar phoenix password recovery software to reset your password.
Nov 05, 2012 | Dell OptiPlex GX520 PC Desktop
How can I reset my logon password if I've forgotten it
Forgot Toshiba login password? You can use Smartkey Windows Password Recovery to help you to reset Toshiba password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jul 15, 2012 | Toshiba Satellite P35-S611 Notebook
Forgot password for adminstrator account?
Forgot aministrator password? You can use Smartkey Windows Password Recovery to reset administrator password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jul 12, 2012 | Acer Computers & Internet
Forgot password
Better try a new password? You con do it by creating a password reset disk. You need a USB flash drive for it. 1. Click to open User accounts. 2.In the left pane click create a "password reset disk" and then follow the instructions. 3.Now you can reset your password with this password reset disk. 4.Log on the computer and windows displays a "incorrect password". Click OK. 5.Click "reset password" and then your USB flash drive. 6.Follow the instructions. 7.Log with a new password. Hope this might help. I've tried this.
Oct 07, 2011 | Compaq Computers & Internet
I forgot the domain controller password and cannot get past the log in screen do you have a way past it ? Thank you Andy Allen
The best and easiest way to reset the local or domain admin password. Reset domain password with Windows Password Rescuer Advanced. By this small software you can easily reset the domain password without lose anything and do not require any tech operation.
Get to the point, now let us see the step-by-step guide to recover domain password with Windows Password Rescuer Advanced. To recover Windows Server 2000/2003/2008 domain administrator/user password, follow four steps below:
Step 1. Download and install Windows Password Rescuer Advanced and use it to burn a Windows password recovery disk with CD/USB..
Step 2. Set the locked computer to boot from CD/DVD-ROM or USB drive.
Step 3. Boot the locked computer from Windows password recovery disk.
Step 4. Reset Windows 2008/2003/2000 local or domain administrator password by a few clicks.
May 08, 2011 | IBM PC 300GL PC Desktop
I dont know my password or email on xbox 360, what do i do
Hi
Hopefully I can help with this.
Go to google and type Windows Live Log In. you should see a link to visit the windows live log in page.
Click "sign in" Click the " Forgot your password" link.
Select "I forgot my password" and "Reset your password
Enter the email address you think you used for Xbox LIVE. Continue entering email addresses that you've used in the past. Once you enter the correct one, a new page will appear. You can guess your email as many times as you want.
Select "Email me a reset link." Click "Next." Open the email account you send the password to. If you forgot your password to that email, use the email client's password recovery tool.
Open the "Xbox LIVE" email and click on the provided link. The link will redirect you to the password reset page. Enter your new password twice. Click "Next
Turn on your Xbox 360 and sign into your Xbox LIVE profile. You should be able to enter your new information to log on to your account and access anything on Xbox LIVE, such as buying a game.
Hope this helped
Thanks
Mar 06, 2011 | Microsoft Xbox 360 Console
I cant not login in too my users i forgot my password
Thank you for contacting Fixya Support, I am glad to assist.
If you are unable to gain access via the password to login to your Mac OS X desktop, you are going to reset your password.
What you will need to do is use the Mac OS X restore (Disk 1) or the Mac OS X installation disk which came with your Macbook Pro.
Now perform this process:
* Insert your install disc
* Reboot your Macbook Pro
* Press the C key on your keyboard and hold until you see the white screen, grey apple, and eventually the spinning gear.
* Release the C key when you see the spinning gear
* When you reach the Mac OS X install environment, click past the language screen.
* From the Installer Menu bar select "Utilities" and then "Reset Password".
* Within the Reset Password utility, select the User Account you need access to.
* Reset the password.
* Quit the Reset Password utility when you have reset and confirmed the new password
* Quit the Installer and restart your Mac..
* At the log in window, enter your username and newly reset password. You should now be able to successfully log in. * I hope this helps.
Regards,
-Mactechtrainer
Sep 13, 2010 | Apple iBook G4 Mac Notebook
Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
May 07, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
