Question about HP iPAQ hw6500 Pocket PC
IPaq switches off
I have an iPaq and it keeps switching off by itself. I have wedged the battery and it did not help. I thought it was the battery cover but I moved it around and it didn't switch off. After it switches off I must open it, take out the battery, put it back and close the back cover for it to start again. This can happen up to 20 times a day. Please help.
I had exactly the same problem but have now fixed it using bluetack!
I first tried Aroldite to extend the hook on the battey cover - it worked for a while but I noticed that the cover was actually stuck to the switch. As soon as the cover came loose again the problem came back. It seems that the micro switch needs to be held in position.
Put a small amount of bluetack on the end of the top hook on the battey cover - try it it works!
Posted on Aug 18, 2008
  • 25 Answers
You need to examine your battery cover as one of the c hooks in your cover may be bent or broken. Basically, the hooks on the cover actually press a micro-switch that detects if the battery cover is on.
If your battery cover looks fine, then you may have a software problem. Try getting a firmware upgrade or simply doing a hard reset to see if the problem is still present
Posted on Dec 03, 2007
My ipaq hw6515 just switches off by itself kind of freezing whats the problem
common problem with this phone, you can try to stuff in a small wad of paper in the little slot that shuts off the phone when you take the battery cover off. So if your phone is face down and you slide the battery cover off on the top right side is a little pointer that pushes a switch that can act up. If you use a smwll wad of paper then put the battery cover back on it may help
Nov 25, 2009 | HP iPAQ hw6515 Pocket PC
Device switches off by itself
the problem is a little microswitch that tells the unit to power off when the back cover is removed... it seems to be a common problem, causing the screen to go 'interlaced' and reset or hang, sometimes shaking causes it to restore itself. solution is remove the back cover (4 torx screws and 1 philips screw under the warranty tag) and glue the switch in the up position...
Aug 25, 2008 | HP iPAQ hw6515 Pocket PC
Ipaq hx2190
hard reset for hx2190
Jun 27, 2008 | HP iPAQ hx2190 Pocket PC
Phone switches itself on
nope... probably you have a software problem.. try restoring it to factory settings or have your fone reprogrammed...
Dec 29, 2007 | Sony Ericsson K750i Cellular Phone
No power to Ipaq 3715
Just did this one, please refer to
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
IPAQ hw6515 reboots by itself
I had same problem.
Culprint was in the back cover.
Above SIM holder is a hidden switch what will connect the backup battery when the main battery is removed.
Small hook (high up) in the cover will trigger the switch. When cover get loose the switch will change it's position.
I put small piece of shrinking tube in it what will extend it 0.5 mm. That did the trick. No more unscheduled reboots.
Jul 29, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Mike, Most PocketPC's will turn themselves on in certain situations: - A taks reminder is initiated - An apointment reminder is initiated - You syncronise your PDA with your PC These are just a few examples. However the PDA should turn itself off after a given amount of time, unless set to do otherwise. Go to your system settings, power, and change the time in which your device turns off. It may very well be that it's set to never switch off.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
HP iPAQ hw6500 Pocket PC Logo
230 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
