Question about Yahoo Messenger
Voice transmission and receiving
One contact I cannot hear, another very low voice. Microphone and speaker diagnostics on my end are ok. Also check out on the callers computers. We each only have our virus protection firewalls running.
  • 84 Answers
Check your playback devices.
Posted on Jul 26, 2009
Cannot hear my voice in microphone
These instructions are for Skype 4.2 for Windows or below. Before continuing, we strongly recommend that you upgrade to the latest version. For Skype 5.0 and above, refer to these instructions. If you're not sure which version of Skype you're using, it's easy to find out.
If the person you are talking to in a Skype-to-Skype call cannot hear you there are a number of steps you can take in order to help you set up your system correctly so that others can hear you.
Try calling Echo123. If you can hear your own recorded voice then your playback device (headphones, speakers, etc) and microphone are set up correctly and the problem might stem from low internet bandwidth, or that the person you are calling has not set up their sound devices properly.
If you cannot hear your own voice in Echo123 check that your microphone is on.
Test Echo123 again to see if the microphone now works..
THANKS.
If none of these steps work you might need to adjust your computers sound setup. Have a look at our Sounds Setup Guide.
Also check out our Troubleshooter for more help with common sound setup issues.
Apr 28, 2011 | Skype IM
My microphone volume of Nokia E71 is very low. Opposite end person can hear my voice at very low volume.
try cleaning your mouthpiece by blowing it with a compressor. should that fail contact a Nokia Agent to replace Microphone.
Nov 19, 2010 | Nokia E71 Smartphone
I already have a microphone but it is still no
Dear! I tell you complete process for microphone.
  • Click on start and choose control panel
  • Now double click on sound and audio devices
  • Use tab or move your mouse and click on voice
  • Now click on hardware test
  • then next and again next and then next again and in the end click on finish.
Now double click in system tray on voice or sound icon (Speaker).
Click on option and choose properties and then click on microphone box if this box is uncheck and if already check then click on OK. Now see the list and look at microphone if it is already check now uncheck it.
Use your microphone you can hear your sound or vice properly now.
Good Luck
Sep 07, 2009 | ASUS P5PE-VM Motherboard
Ok, i have one CB that is a realistic TRC-474 and it powers up just fine and everything works except theres no noise at all coming out of the speaker! However, my buddy pulled up next to me and i could...
there a several things you can check yourself with a minimum of tools or test equipment. this model has been around for several years and voice coils do expire in the internal speakers as they age. attempt to locate a known good external speaker with a 3.5 mm plug and see if the receiver can be heard through it. if so then the internal speaker has seen better days and the solution/s should be obvious. also in this particular model the receiver output is controlled by the microphone switching and an open receive line in the mic cord/cable or the plug itself would render the receiver unhearable. check with another known good microphone wired for realistic radios (5 pin DIN). the microphone might also have been rewired improperly. make sure the squelch is in the fully counter-clockwise position and the volume is adjusted to a suitable level while testing, 12 o'clock or higher.
Jun 10, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Nokia E65 microphone doesn't work
hi thanks for using fixya!!
Did you accidentally dropped the Nokia E65? Well, on this error, you shoudl bring your unit to a service center to further check the hardware error such as the microphone. However, be sure that whenever you make calls you have the network signal high so that you can have quality voice calls.
If you need further assistance, let me know
May 26, 2009 | Nokia e65 Cellular Phone
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
Pc to pc talk my voice heared very low(input voice low)
you need to install the smart audio driver 221 for your laptop the mute problem should be solved with that and should increase voice qty a little. I guess you are using Win XP
Jan 26, 2009 | Compaq Presario Notebook
How to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Apr 24, 2008 | Logitech USB Desktop Consumer Microphone
Yahoo Messenger Logo
82 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
