Question about Memorex (32023239) External Floppy Drive
Mac won't recognize usb drive
I got my macbook to read a single floppy, and then it stopped picking up the drive. Another windows laptop can recognize the drive, but my mac can't. Help?
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
For MAC users I am sorry but apart from the above steps that is all I can offer.
Posted on Sep 01, 2009
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Silicon power a80 has all my movies on it from my mac book but now i try plugging into my tv or blue ray player and router and nothing will recognize it
A: Does your tv have a usb port and drivers to recognize a hard drive? WE don't know you did not provide that information.
B: Same for your Blue ray player
C: Same for you router
D: Mac file system is not the same as Windows file system
Mar 25, 2014 | Silicon Power Armor A80 1 Terabyte 1TB...
Imation Model D353fue not recognized by MACBook Pro
It is a "plug-and-play" USB-device, and *should* be recognized, if the hardware inside the case is in working order. So, exercise that "warranty" to get it replaced.
Try connecting it to a Windows PC (XP/Vista/7/8), to see if Windows will recognize it.
Feb 02, 2013 | Imation Model D353fue External Usb 3.5"...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I am using a Mac Pro. My SmartDisk Titanium Edition Will not read a double sided floppy disk. It will read a regular floppy disk. What can i do?
Windows XP "natively" supports this "plug-and-play" USB device.
So, if it is "dead", search eBay for "external USB floppy" and buy a replacement.
Jul 18, 2011 | SmartDisk USB Floppy Drive Titanium...
Switch on - screen is grey with flashing folder with questionmark
Hard drive is dead or the signal from the hard drive is not being read by the ide controller. I'm working on a MacBook 13 inch right now with the same issue. I had a spare hard drive and a windows Vista disc, so I installed the hard drive and inserted the vista install disc and the laptop loaded and installed Vista on the Mac with no issues. I took the hard drive from the Mac and attached an adapter to it and ran it through a usb on another laptop and the laptop could not read the files on the drive....so, the drive was bad.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sandisk Cruzer 1GB drive suddenly not working
DO NOT panic! Try this: restart your computer and plug your USB in again(this helps to clean the buffer), see if you drive can be recognized.
If you still can't access the data inside, try this data recovery program Wondershare Data Recovery. Get the program here,
Mac Data Recovery (Mac OS version)
Windows Data Recovery (Windows Version)
Take care - Before those items are recovered, stop saving more files to the USB in case the file data are overwritten!
Feb 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Nexxtech usb external floppy drive
The simple answer to your question is yes. The trick is getting the external floppy drive.
If you have one you should be able to connect it to you mac and simply drag the files on to your desktop. Depending what the files are you should then be able to still read them and save them on the mac in a new format.
It really depends on what format the files are and what app they where created in.
Floppy disks! I have not come across them for years! The process is quite slow!
Sep 30, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Memorex (32023239) External Floppy Drive Logo
6,998 people viewed this question
Top Memorex Computers & Internet Experts
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Jose Velazquez
Jose Velazquez
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
