Motherboard E210882 on Emachines Model W2888 pin configuration
I have an Emachines Model W2888 with motherboard E210882 and I do not know in what order the 3 2-wire plugs for the PWR LED, PWR S/W and HDD LED go on the pc board. I removed them all at once , thought they were all on 1 plug like an HP.There are 3 white wires on each plug, and a red, green and black.I Really need a wiring schematic, any help would be appreciated.
    President:
  • 2,559 Answers
Here is a link to the manual,It is in PDF format
Posted on Jul 21, 2009
On/Off pins on motherboard wiring giagram e210882
http://www.productmanualguide.com/dell-motherboard-e210882-manual.html
Apr 12, 2013 | Dell (E210882) Motherboard
I took the front off the e machine w2888 desktop but did not notice the three wires was not one plug, what order and colored wire up or down. Their is a pwr led, pwr s/w, hdd led wire. Thanks Jerry
The eMachines W2888 uses an Intel D845GVSR motherboard.
This is the download page for the Intel D845GVSR motherboard manual, (Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the first file name in blue -
Intel Desktop Board D845GVSR - Product Guide (PDF)
This is a PDF file. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
[ Took 4 seconds to see the first page come up, just now. File was fully downloaded ]
At the top of the PDF file is the page number box. It is to the right of the blue Down Arrow.
This is the page number I will be referring to, and may not be the actual page number of the manual.
Go to Page 11.
This shows an illustration of the motherboard looking down at it from the top.
The letter S points to the Front Panel header.
[The plastic front of your computer is the Front Panel.
The area of pins on the motherboard that the cables (Wires) go to from the Front Panel, is the Front Panel header ]
Looking at the motherboard with the Processor to the top, Ram memory slots to the right, and the white PCI slots (3) to the bottom, the Front Panel header is located parallel to the bottom right edge of the motherboard.
(The illustration has the motherboard sitting on it's right side.
Not the direction it is sitting in your computer.
In your computer the motherboard is sitting as described above )
Now I would like you to go to Page 31.
This illustration shows the various internal headers on the motherboard.
The letter C points to the Front Panel header. (J9G1)
Note that the pins in the Front Panel header are labeled with numbers.
(Pinout)
There are 4 pins across the top.
There are 5 pins across the bottom.
Starting from the Left side of the motherboard, going towards the right, across the Top of the Front Panel header;
Pins 2, 4, 6, and 8.
Starting from the Left side of the motherboard, going towards the right, across the Bottom of the Front Panel header;
Pins 1, 3, 5, 7, and 9
Page 32: Front Panel Header
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive ( + ) wire.
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF used.
Pin 5 is for the Ground ( - ) wire.
C) Pin 9 is for a 5 Volt wire. (It's probably Red in color, IF used)
D) Pins 2 and 4 are for the Power On LED light. (Light Emitting Diode)
E) Pins 6 and 8 are for the Power On switch. (The Power On switch is located inside the plastic Power On button assembly)
F) Pin is N/C. Not Connected.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 10, 2011 | E-Machines eMachines Desktop PC
I have the e210882 motherboard and i have a prob with "bios" cant get in.. Need password..how can i fix this?
Hi!
It so simple, you don't need to blow your mind looking and thinking of the password. Just reset the BIOS jumper configuration straight from your motherboard and the password will be gone.
Open your computer system case and then look for this thing:
Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
Its done! The password is gone!
Or you can try also this procedure.
- Just remove the BIOS battery and place it back.
Refer to your motherboard manual to do this as reference.
Have a nice day!
Thank you for reaching us.
May 20, 2010 | Dell (E210882) Motherboard
Front USB Pinout Diagram
Visit http://www.intel.com and find the user's manual of your motherboard. Such informations are given in the user manuals. You can also download user manual from http://support.dell.com from download or support section. (ehteshamhusain@gmail.com)
Apr 21, 2009 | Dell (E210882) Motherboard
Wires connection
the display some time come and some time not come
Jan 30, 2009 | Intel D845GVSR Motherboard
Emachine model W2888, wiring
this is someone more suited for a trained technician, but you can look at the motherboard, where the pins were, and you should see markings like pwr +, pwr -, led +, led -, hdd_led, etc, you will also see markings on the cords that connect to the motherboard, with the same words, pwr+, pwr-, etc, you can try matching those up..
Jan 20, 2009 | Gigabyte GA-8IE533 Motherboard
INtel Motherbd E210882
I would start at eMachines support website
You will need to know the Product type, series and model number.
Alternatively, go to Crucial's website and use them to determine the RAM you need. They are an excellent source for RAM. You will get quality and a great price. Use their memory advisor tool.
Jan 26, 2008 | Intel Motherboard
Computers & Internet Logo
1,428 people viewed this question
David Payne
David Payne
