Question about Lexmark X1150 All-In-One InkJet Printer
Copy will not work on printer itself
I can make copy using computer but when I push the copy button on printer itself nothing happens
    President:
  • 2,306 Answers
The 1150 is not a stand alone copier, the only way the copy function works is when the machine is connected to the computer and the program is running. I never liked that much here in the repair shop because in order to service it I have to connect to a computer.
Posted on Jul 21, 2009
Nothing nhappens when i push scan start button
dear sir good day to make this button functions you must install the printer setup cd and it'll make the computer undrstand the push of the buttons of your printer thank you
Jan 07, 2010 | Lexmark X3480 All-In-One Printer
When I plug in the printer, the screen lights up, the "on" button and the "cancel" buttons light momentarily but nothing happens. The screen stays lit and pushing the on-off does nothing. It will not...
Try this: first disconnect the power cord from the Printer, then disconnect the USB cable, then unplug the printer power cord from the wall. Wait 10 minutes and plug everything back in In Reverse Order. See if that does it. I had a similar problem with my PSC 1610v and that is what HP had me do and it worked for me.
Jan 01, 2010 | HP PSC 2355 All-In-One InkJet Printer
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
Oct 29, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP6310 does not scan or copy using flatbed glass
Hi
Try connecting the printer to a direct wall outlet and not to a surge protector
try a partial reset
for this
you need to unplug the power cable from the printer
press and hold the # and the 3 buttons on the front panel and then replug the cable,
do not release the fingers until you see the LCD lit up.
let the printer initialize itself and then try making a black and white copy
if it makes a copy ,it should definitely scan now.
for any clarifications or assistance ,feel free to contact me.
Aug 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Apr 10, 2009 | Office Equipment & Supplies
Copy problem hp 6310 all-in-one
Instead of pushing the Ok button you should push the "Start Copy - Black" or "Start Copy - Color".
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Dell 1600n - nothing happening when I push Scan Button
I had the same problem as both posters.
I downloaded the most recent firmware from dell (3.11T, A03) and reinstalled it. When you run the program, there's a radio button that says "printer" and one that says "network". I did the one that said "printer" and nothing happened. Then I ran the firmware update again and picked the one that said "network" and it started working shortly afterward.
I'm assuming that some component of firmware in the network card was messed up. I could still use the network printing but the "scan" button wasn't working. This fixed it for me. Your Mileage May Vary.
Aug 19, 2008 | Dell 1600n All-In-One Laser Printer
Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
Jul 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Machine Unresponsive
HP Support:
Try resetting the unit by unplugging the unit while its on, then holding on the # and 6 keys plug the power back in an continue to hold the # and 6. The printer will power itself down, the reset is complete; turn it back on using the power button and attempt a copy.
If the unit has never been able to make a copy, it is likely that unit is defective.
Mar 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark X1150 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
