Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 Range - Buzzing sound when plugged into electrical outlet
We just installed a barely used GE XI44 range/oven and it's making a buzzing noise. It quit buzzing when I used the stovetop yesterday, but later after turning off the stove it began buzzing again. Sounds like a timer going off, but the timer wasn't set. Please advise. Thank you.
SOURCE: range does not work-message on stovetop reads 5Ab
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Gene.
Posted on Mar 09, 2008
yalmer
  • 549 Answers
SOURCE: buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
Posted on May 20, 2008
SOURCE: Ge Profile XL44 - Everything works except the Oven, it just stopped
I figured out what the Issue is with my oven. I took off the back panel, a wire which runs from the teperature control knob to what I think mught be the thermostat is burnt off. I cleaned the wire and temporarily twisted it back on and the oven works now. I will call a tech tomorrow to replace the wire and put the tester on it to make sure the thermostat works properly so the wire wont burn off again or catch the oven on fire.
Posted on Dec 11, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
  • 439 Answers
SOURCE: Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Posted on Jun 21, 2009
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
I was cleaning my ge flat top electric stove when i heard a buzzing sound and the oven controls quit working
Sounds as if moisture has gotten into the oven controls. If it did the control has shorted out.
Feb 01, 2010 | GE Profile JDP47 Electric Kitchen Range
Kenmore propane stove (16 yrs old). Oven quit working yesterday
is ther a slight propane smell around the stove?i'm thinking your oven pilot light got blown out
Jan 31, 2010 | Kitchen Ranges
When the door is closed it makes a buzzing noise, the micro still works and the noise goes away when turned on and used
Is it possible that the other noise produced when using the oven are only covering up the buzz?
I think your microwave has two power supplies; one that supplies the low voltages for the display and control, the other for the magnetron. The first supply may be a standard line frequency unit using an iron-core transformer and if these are cheaply made, the laminations can vibrate and cause a 'buzz.' Better transformers are 'potted' so that the laminations are glued together with epoxy and can't vibrate. On later units, the magnetron voltage is produced by a 'switched mode' power supply that uses solid ferrite instead of iron and never vibrate.
If it was my unit, I would take it far enough apart to run a couple of beads of epoxy glue across the laminated transformer to kill the resonance.
Nov 15, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Jun 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Nov 13, 2008 | GE JE1860 Microwave Oven
HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Oct 21, 2008 | KitchenAid KESC307 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
396 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
