Question about Konica Minolta Office Equipment & Supplies
Cannot print a manal with the finished size as 5.5x8.5 folded and stapled. IT SHOUD PICK UP THE 8.5X11 PAPER AND FOLD AND STAPE IT BUT IT DOESN'T. Please HELP.
  • Norman  J Weimar Jr
    Norman J Weimar Jr May 11, 2010
    Is the paper properlt oriented landscape or porait? Printing it? Network? properties on printer window? Will it do at the machine coping?
  • Konica Minolta Expert
  • 158 Answers
For the 8.5x11 paper to staple the paper has to loaded in the machine with the short edge of the paper fed first so if the paper is turned the wrong way in the paper tray the machine will reject the fold command it should say on the paper type setting 8.5x11R
Posted on Oct 15, 2009
Tip
Rocket Grill - How to make Inexpensive bags - As low as 2 cents each
Many of us have Rocket Grills which we love, but the bags can be expensive, and it is a pain if you run out of them when you want to use the machine. Here is my solution which I have been using since the machine was originally released. They will hold fat and juice too.
First of all, you are going to need to get some parchment paper. I buy bulk 12 x 16 sheets from a supplier off eBay. (Remember the more you buy, the lower the price). In an emergency you can use a similar technique with Reynold's Parchment paper rolls from the store.
You Need
A. 12 x 16 Parchment Sheet/S
B. Stapler
C. Sharp Pencil or Pen
D. Table or Flat Surface
D. (My Optional Template)
Instructions
A. Take one sheet and fold it in half. so you have an 12 inch wide by 8 inch deep sheet. Crease the sheet by running your finger firmly over the fold.
B. Place the folded sheet on the table, so that the fold is at the bottom as you view it.
C. Now along the short open sides (left and right sides of the sheet), one at a time, fold both layers over as a flap about 1 and a half inches. Try and keep both of these folds to the top.
D. Using a stapler, Staple each side that you have just folded one inch from the top, and a quarter inch from the edge on each side.
E. Turn the parchment paper 90 degrees counter clockwise so that the sealed bottom faces to the right.
F. Take the bottom part of the flap that you created in section C, and fold it back at a 45 degree angle. You should end up having two equal size triangles.
G. Turn the paper back around so that the first fold (A) is at the bottom again.
H. Staple each fold that you just created, about a quarter inch from the top of where the folded edge is. (see picture)
I. Place three equal spaced staples in-between the two staples you just did in section H. You should now have 5 stales in one line, about an inch and a half from the bottom of the bag.
J. Pick up the bag, softly fold it in half in the opposite direction as of section A. Make a tiny crease in the top (Open section). This is so we can find the center of the bag.
K. Place the crease over two of your fingers, and gently push the Pencil or Pen through the crease about 3/4 of an inch from the top. Do not rip the bag) This will be used hold the bag in the grill. (I have cooked 1lb steaks in the grill, and the hole holds the weight fine. Be gentle though)
Comments
A. I know that it is possible for the staples to lightly scratch the grill. However the Grill pads are not designed to come into direct contact with food anyway, and will not damage the grill
B. Some people may wonder about using staples near food. If you use new staples from a clean box you will have no problem. The heat from the grill will sanitize any impurities that may be on them. Also not that it is highly unlikely that your food will ever touch the staples.
C. The pouch at the bottom will hold fat and juice, but depending on the quality of the paper you buy will determine how well the bag holds up. It is possible for the juice/fat to weep through the staple holes, but thats why you have a drip tray.
Thats all folks. Message me if you have any questions.2bda07b.jpg39f5fe9.jpgb6d7936.jpg7040cb1.jpga957872.jpgcbfcbde.jpg
on Apr 17, 2010 | Kitchen Appliances - Others
Print a booklet with a cover
well would have to know the model the spec on the paper and do you have a finisher
Jan 30, 2014 | Konica Minolta bizhub Office Equipment &...
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Konica Monolta c550. ignores trifold
the fold function is only available when the option finisher fs-608 is installed . here is the steps to make a trifold on a fs-608.
1 open a one page document it can only be 8.5x11 in size.
2 click file then print and pick the konica c550 in the printer name box. click properties.
3 in the output method select print leave the paper tray on auto leave the paper size on same as original click original size to indicate 8.5x11click on the radio dial to indicate portrait under original orientation.
4under the layout tab leave the following fields blank-combination,rotate 180,skip blank pages,binding margin and image shifton the right side of the layout screen leave print type as one sided and binding direction on auto.
5 under the finish tab leave paper arrangement at its default= prioritize arranging papers.make sure there is a check mark in the fold box and select trifold in the drop down menu.
6 click ok and go to the c550 to retrieve the document
Nov 05, 2009 | Panasonic DP-C264 Copier
What does saddle stapling mean?
Saddle stapling is making a book of pages by stapling the spine at the back of the document to keep many pages together.
Apr 28, 2009 | Canon imageRUNNER 2200
Help Konica Minolta c351 mac user
One is that the fold and staple option only works on 8.5 x 11 sized paper, thus printing onto a 11x17 spread and then folding. If letter paper is not selected, that will grey it out.
Nov 03, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica C350 questions
You can print envelopes from any software, like Microsoft Word. Just be sure to enter the proper settings at the copier as fatr as size and media weight/type.
The copier should be able to fold 3 sheets, but that depends on what model finisher you have. To fold you need to load the paper landscape, so it runs through on the 8.5 side and not the 11 like normal.
Jun 27, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Mail merge tri fold printing
Whats the weight of the paper? Try a lighter weight paper. Also, did it do it when you first got it? If No, it is called a limitation, it can't be done. If it did have your service tech come out and clean or replace the feed rollers or clutchs.
Feb 04, 2008 | Panasonic DP-C264 Copier
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
116 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
