Question about Nextel i265
Turn Off Airplane Mode
How do you Turn Off Airplane mode for the Motrola i265? the manual just says "turn off" and does not include the actual steps.
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Airplane Mode..
Here is the link to the user manual; http://www.nextel.com/assets/pdfs/en/support/guides/phones/i265/ug.pdf Check page 119 of the manual (129 of the pdf)says: "Sometimes you may want to have your phone on,but turn off its ability to make and receive calls, such as when you are on an airplane. To set your phone so that it cannot make or receive phone calls, Direct Connect calls, Group Connect calls, Talkgroup Calls; or transfer data: 1 From the main menu, select Settings > Advanced > Airplane Mode. 2 Set this option to On. This icon U appears. Note: Pressing p for more than 5 seconds also turns on Airplane mode. To restore your phone?s ability to do all these things: Set this option to Off." Hope this helps :)
Posted on Jun 29, 2007
Nextelneo
  • 133 Answers
SOURCE: airplane mode
It usually means the phone has incurred liquid damage have the phone check at a service center. There is no real long lasting fix for a liquid damaged phone
Posted on Dec 07, 2007
  • 51 Answers
The airplane mode can be turned off by switching off the mobile and switching it on again. Ask *********** to switch off her mobile as she would do it normally ( if she does not know how to do that, there should be a power button for every mobile, so holding it pressed will switch it off) and then she can switch it on again. So when the mobile gets switched on, it will ask for options for flight mode or normal mode. The normal mode can be selected now. This is how it happens in my sony ericson mobile. If this does not help, let me know your mobile model number.
Thanks.
Posted on Nov 03, 2008
SOURCE: Can't get phone out of Airplane Mode.
Remove the battery and SIM card. Put battery back in and start up. If should say "insert SIM". Then remove the battery and replace SIM. The you will be prompted to "Allow Transmissions". Click Yes and then you're all set. I hope this helps. It worked for me.
Posted on Mar 10, 2011
Why cant i turn off airplane mode on a huawei m920
You can simply turn off or disable airplane mode by following these steps:
1. Press the Application Icon.
2. Then, click Settings and choose More.
3. Next, tap Airplane Mode to change the settings. Make it sure you`ve Unchecked Airplane Mode.
4. You can now go back to the Home Screen by clicking the Home Key.
Jul 06, 2014 | Huawei Cell Phones
How do i turn iy of
Menu -> Settings -> Advanced -> Airplane Mode, and set it to Off.
Mark
Motorola Support
Feb 06, 2014 | Nextel i265
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
Jan 04, 2014 | Nokia Lands Phones
It says wifi unavalible
Turn Airplane mode off. Airplane mode shuts off any radio signals that would interfere with airport communications including wifi.
Dec 01, 2013 | Gateway NV76R24u Core i5-3210M Dual-Core...
Iphone 4s wifi cannot turn it on
Follow these steps to resolve the issue:
  1. Verify that airplane mode is off by tapping Settings > Airplane Mode.
  2. Reset the network settings by tapping Settings > General > Reset > Reset Network Settings.
    Note: This will reset all network settings, including Bluetooth pairing records, Wi-Fi passwords, VPN, and APN settings.
  3. Ensure that your device is using the latest software. To do so, connect your device to your computer and check for updates in iTunes.
  4. If your issue is still unresolved, perform a software restore in iTunes.
Sep 23, 2013 | Apple iPhone 4S
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
My phone keeps saying no service. What do I do?
Assuming you did the initial troubleshooting:
Battery pull and sim card removal; then place sim and battery back in.
The next step would be going to one of your carriers stores.  They can give you a test sim to put in your phone to verify whether or not its the sim card.
Hope this helps,
Bill
Oct 14, 2009 | Cell Phones
Airplane Mode..
Jun 29, 2007 | Nextel i265
Cell Phones Logo
247 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
ray gallant
repairphone
repairphone
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
