Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
48 inch deck problems
My Husqvarna yth2348 was purchased this Spring (2009), when mowing there is a missed strip of grass (most bent over) on the left side of the deck that looks to be on line between the front and left blade. It has done this since I bought it.
I have sharpened the blades, leveled the deck to specs, cleaned the deck, checked for blade alignment (bent deck), ends of blades are not worn and ends are square, made sure tire pressures were correct.
This makes my mower a 30 inch deck because I have to overlap each pass to get the missed strip from before.
Other issues with this model:
Throttle control on top gets pushed back to idle when mowing under bushes.
Grass buildup in the deck drops all at once killing the engine instantly.
Briggs engine backfires a lot when not under load.
When mowing my ditch, if the right side of the deck gets pushed up on the adjacent slope and the tractor gets stuck, you cannot back up because the raised deck stops the reverse pedal from being depressed.
  • 44 Answers
A lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Posted on Jul 21, 2009
Husqvarna yth24v48ls leaves streaks of uncut grass
What are the size of the streaks? and where in the 48 inch swath?
Aug 06, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 just quits while mowing...
check the coil on it,not a fuel problem if the coil gets hot it will shut down and when cool cranks back up,my dad is a lawnmower mechanic!!!
May 14, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
There is a big, wrap-around lifting bar in the front of my Husky used to raise the engine assembly off the mowing deck but I can't figure out how to free the engine assembly so I can pivot it up to expose...
most rideons have the deck assembly able to be removed without too much work.usually release any spring tension,then spring clips holding the arms on,then usually you can disconnect the belts and slide the whole deck out sideways,from under the rider.
Jun 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
MY husqvarna yth2148 left side deck mandrel and pulley failed. I bought a new mandrel and pulley and installed same. Mowed the lawn twice and it failed again. any suggestions
Did it break or overheat? There is a small spacer washer that goes under the pulley between the pulley and bearing, if that washer was missing or got ground up on the first one and you didn't notice it the next pulley would rub hard against the top of the mandrel and fail.
Jul 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,147 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
