Question about Desa International Home Security
Lost transmitter for wireless alarm - Desa International Home Security
    Scholar:
  • 177 Answers
You'll need the Brand name and model number. Then you can Google the company's name ,go to their website and maybe they'll sell you a replacement transmitter. Some companies do sell replacement parts, some don't.
Posted on Jul 21, 2009
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
Have a 1998 xj8 car drives no probs opens no probs with key but after a recent batery disconnect will not open the car with remote
Since you lost power your "fob" and receiver may not be communicating any more.
This is a process to for your fob to re-sync with your car.
Note : All transmitters being serviced must be available. If the learning process is carried out without having all the transmitters present, all previous transmitter codes will be overwritten, rendering the missing transmitters inoperable.
Hold headlight flasher back.
Turn ignition key to position 1.
Flash headlights 4 times.
Alarm will enter programming mode.
This will be confirmed by "beeps" from the alarm and flashing led on gearshift.
Program each transmitter (up to 5) by pressing the lock or unlock button on each transmitter once.
The alarm will "honk" when you press the transmitter button.
The alarm must honk 5 times to complete the programming. Therefore, if you are only programming one transmitter you should operate the transmitter 5 times.
If you are programming two transmitters you will operate one transmitter twice, and three times on the other.
For five transmitters you will operate each transmitter once.
Good Luck!
Oct 16, 2013 | 1998 Jaguar XJ8L
My GE Home alarm system will not stop beeping. It beeps 3 - 4 times every 10 min. When I press the * button it says that the garage door sensor has been tampered with. YES, I had to open it and change the...
Sounds like the garage transmitter is bad. The system polls it's transmitters every 2 - 3 minutes. If the received does not get it's proper response it is supposed to inform you by beeping. Also, if the transmitter has a built-in tamper switch it could not be making the required contact. Usually it is the transmitter. Hope this helps
Oct 03, 2012 | GE 80-860-4 - Concord 4 Wireless Alarm Kit
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Sep 14, 2010 | Audio Players & Recorders
Alarm going off-says front door problem, but front door is fine. How can we stop alarm from going off?
If your front door is using a wireless transmitter then the problem is most likely a mis-aligned contact. Most alarm installers will install the transmitter with built in contact on the door molding and a small magnet on the door itself. There is generally an alignment mark on the transmitter case so you know where to place the magnet. The magnet should never be placed more than 1/2 inch away from the transmitter. Be sure the alignment is correct as well as within the spacing requirements. If this was done properly another possibility is either a defective contact or in some cases a loose fitting door with excessive free play could also be causing you a problem. Make sure the door is tight when closed. If your door contact/transmitter is of a different design such as an external contact wired to the transmitter let me know the specifics (type of contact ie., hidden press fit, plunger, surface mount) and I'll give you additional information regarding what to look for. I have over 30 years experience in the alarm business and am sure I can help you.
Aug 29, 2010 | GE Security Simon 3 Wireless Home Security...
Alarm wont sound
If your door is protected by a wireless transmitter your problem is most likely a defective switch or a grounded wire from the switch to the transmitter. To determine if the transmitter is working properly pop off the top of transmitter case by using a small blade screwdriver. If you look on the side of the casing you will see a small slot where the screwdriver is placed. Insert the blade of the screwdriver there and twist. The top of the transmitter will release. Inside you will see a small circuit board and battery. If an external switch is used you will also see 2 wires connected to the circuit board which then leads to the swtch. Using a very small screwdriver remove these wires. Now go check system status at your keypad. If the system recognizes the door as open then your problem is a bad switch or pinched wires that are grounding out the switch. If the keypad's status says the door is still closed the problem is in the transmitter. Sometimes these transmitters will be installed using an internal contact/switch.To know if this is the case on your door you will see only the transmitter mounted on or next to the door and a small magnet within a half inch or so on the opposing side. If this is the case your problem again is the internal switch. For replacement of external switches you can try going to a Radio Shack where they offer an assortment. Hope this helps.
Mar 30, 2010 | GE Security Simon 3 Wireless Home Security...
2002 Toyota camry factory alarm
get a used one.it can be reprogrammed with the obd2 system for 100 bucks.
May 15, 2009 | 2002 Toyota Camry
1999 Jetaa
your transmitter has posably a bad battery or the transmitter codes were erased when you took the battery terminals loose
Aug 26, 2008 | 1999 Volkswagen Jetta
Home Security Logo
52 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
