Question about Garden
My L118 John Deere Lawn mower doesn't want to go up hills or even move after it gets hot. what is the problem?
This unfortunately is a common problem. I had the same issues. I had a professional check tension in belts, and even drain tranny fluid & replace with a heavier weight fluid as recommended on the Internet. Still have same problem. 2 solutions. 1. Replace hydrostatic motors inside the transmission. Look online for for video/instructions. 2. Replace entire transmission.
Posted on Jul 22, 2013
My L118 wp pulling up hill how come?
Posted on Apr 14, 2013
  • 44 Answers
Check drive belt tension when m/c is off.remember OFF! if too loose,refer to manual.
Posted on Jul 21, 2009
  • pat gilmartin Jul 21, 2009
    dont know if i answered this. with m/c OFF! check drive belt tension, if too loose, will slip and engine overheats and therefore cannot go uphill. refer to manual.
L118 JD 22 hp wont pull up 30 degree hill. Engine good . Have not changed belt. 250 hrs. Read about trany going bad. hope not. Any way to tell if its the belt or tranny?
if the belt has any cracks or missing any thing or looks bad in a spot replace it. if you are using it a lot on hills or to pull a lawn cart the belt will wear out faster. replacing the belt is cheaper than a transmission.
Jun 17, 2017 | John Deere Garden
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
What is the configuration of the mower deck belt on a john deere 42 inch mower deck model L118
John Deere L110 Lawn Tractor Service Repair Manual
Feb 25, 2017 | John Deere Garden
I have a John Deere lawn tractor L118 42 inch cut. As I cut my lawn, initially it runs great. However, the last few passes, the mower looses forward speed and barely carwls and has no reverse, When it...
Hi, the most likely cause is the transmission over heating. Remove the battery and the cradle underneath the battery. Here you should be able to access the transmission. Clean all grass and debris from the cooling fins and check the cooling fan for damage. Hope this helps. Regards Phil.
May 03, 2011 | Garden
I HAVE A JOHN DEERE L118 RIDING MOWER AND TODAY WITHOUT ANY WARNING THE MOWER JUST STOPPED MOVING.I HAVE NO LEAKS OUT OF THE TRANSMISSION AND THE BELT IS NOT THAT LOOSE. THE LINKAGE IS ALL GOOD AND TIGHT....
yes,,, they just go bang,,if its striped the drive key they just stop,
have a look at the pully ends if you can turn one with out nothing moveing the key has striped take off the pully and replace the woodruff key,,easy to fix some times?,
Aug 08, 2010 | John Deere Garden
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
John Deere L118 Riding Lawn mower speed problem
I have lost the key to my John Deere Model L118 lawn mower. Where can I buy a replacement?
Mar 16, 2009 | Garden
Garden Logo
1,181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
