Question about Fisher Paykel EcoSmart GWL15
Musty smell especially in towels
When towels are dampened or wet the towels smell musty.  I've tried febreez, tide odor detergent - and still nothing.
    Problem Solver:
  • 18 Answers
Once towels have had mold grow on them, it's unlikely you will ever get rid of that smell. You can usually tell a towel has had mold grow by discolorations on solid color towels. You probably need to start over with new towels, make sure they are washed and dried frequently and that they don't stay damp for long after showering. If you live in a humid climate, a towel warming rack will help with drying.
Posted on Jul 21, 2009
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
Jun 12, 2012 | LG Washing Machines
What causes a bad smell to come from a washing machine
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
This is a very,very frustrating mistake that gives owners much grief.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Dec 12, 2010 | Washing Machines
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
Clothes have a mildew smell
Hello billpmm,
You are not alone with this problem. Seems that that everyone of the front loader washers exhibit similar characteristics .. the short story is that in order for a washing machine to be a front loader, they need to be water tight .. being water tight, they are also air tight and herein lies the problem.. any water left over from a wash cycle will sit in gaskets , nooks and crannies and eventually develop mold or mildew.. here is a link to product you may find that solves your problem
http://www.smellywasher.com/
or.. you can use the AFRESH tablets sold in Home Depot and other home improvement stores.. in either case.. these products will help rid that musty mold out of your washer..
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Leaking from the front of washer and moldy odor.
you need to replace the front boot what a pain you may need a tech to do this also you need to keep door open and wipe the boot with a towel after each use this is a common problem with front loaders.I do warranty work and run across this problem alot
before you replace boot turn on washer with nothing in it and let it cycle if you see suds in water you are using to much soap and this will cause the machine to over fill check this first
Dec 02, 2007 | LG WM-2277HW Front Load Washer
Kenmore elite he5t washer
I too have a HE4t washer. When I bought it, the Sears sales man said that after doing the wash for the day, you have to always wipe out the insides of the rubber gasket. If you do not do this, you will get mold build up. I an anal about doing this and for 6 months now have had no mildew smell. However, I went on a trip for 2 weeks and when I got back, there was an awful mold smell. I checked the gasket and sure enough, there was gunk build up. Needless to say hubby and kids did not do the maintenance. I had to wipe it up several times with bleach to remove the mold spores. Then I ran a sanitary cycle with pure bleach. Smell is gone thankfully.
But don't you think it's ironic to have a $1500.00 machine that needs to be babied after the end of the day?
Oct 17, 2007 | Kenmore Elite 45986 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
398 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
