Question about LG VX8350 Cellular Phone
Programm ing one stop dialling
I have managed to wipe out all my one stop dial telephone numbers in my Toyota Prius. I do not have instructions to reinstall the numbers and Toyota Customer services said they didn't know how to do it! Is there a web site where I can down load the instructions please? Or can you help me? ( I have no recollection of how I managed to programme it in the 1st place..)
  • jane838 Jul 27, 2009
    SORRY- but these sights were com-letely useless.
Why does the phone not call out ? It says the way the number is dialed doesn't work?
Did you read the instructions that came with it? I am wondering if you have to dial 9 to get an outside line if this is a home PBX unit?
The other possibility is that the phone is not set to tone dialling and is set to pulse. When you dial, do you her musical tones or clicks corresponding to the number dialled?
Comment back with Make and Model as a comment to this post.
Nov 24, 2015 | Lands Phones
What is principle behind pulse dialling mode & tone dialling mode in technical terms
Pulse dialing is a holdover from Rotary phones, which when the rotor is turned and let go, counts out the number you entered in clicks on the telephone line. Pulse, or DTMF (Dual-tone multi-frequency), uses two overlaid tones (one for row and one for column) to signify a button press.
DTMF frequencies:
http://en.wikipedia.org/wiki/Telephone_keypad
Mar 19, 2011 | Cell Phones
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
There is a fax tone when dialling our telephone number.
Set your fax to MANUAL MODE. You will have to press START when you know you are getting a fax.
This is the only way it will work without a dedicated fax line.
Nov 30, 2009 | Canon FAX-JX200
International dialling codes
After dialing 011, the 3 digit code for Lithuania is 370. Dialing 011+370+(phone number) should work. Add 2 0's to the370 if a 5 digit couintry code is necessary. Below is a link to help with interational calling. All the best!
Greg
http://www.q7c.com/travel/telephone.htm
Jun 17, 2009 | Office Equipment & Supplies
Can't dial abroad
how are you dialing the number on the phone, what is the number, if your are not dialing it correctly it will cause this,
i.e i believe austria is 00 + 43 + Area Code+ Tel #
and norway is 00 + 47 + Area Code+ Tel #
if you go to www.countrycodes.com this will help
Jan 01, 2009 | Lands Phones
Programming speed dial numbers
just hit the phone button type in the number a button will highlight that says add to speed dial
Dec 01, 2008 | 2007 Toyota Prius
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
Oct 05, 2008 | Philips DECT 2151 Cordless Phone
Modem, Dial Up Connection Problem
here's some help...go to : start menu,all programmes,accessories,communications and to hyper terminal..type in test, and click o.k.,make sure all the settings are o.k., type in your mobile or your second land line number to test if the modem dials that number.if that test works then contact your i.s.p to check on your account.
Sep 03, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
LG VX8350 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
