Rename all instances of your document template files (Normal.dotm or
Normal.dot). This will prevent formatting changes, AutoText entries,
and macros that are stored in the global template (Normalm.dot or
Normal.dot) from affecting the behavior of Word and documents that are
opened.Renaming the template will let you quickly determine whether the
global template is causing the issue.
When you rename the
Normal.dotm template in Word 2007 or the Normal.dot template in Word
2003 and in earlier versions of Word, you reset several options to the
default settings. These include custom styles, custom toolbars, macros,
and AutoText entries.
It could mean that the normal.dot file is corrupt.
Try this:
1. Do a search for normal.dot
2. when found, change the name to "normal.dot.old"
3. restart your machine
Good Luck !!!!!!
Thanks markwganser,
I tried that on 2003 and it never worked. I updated to 2007, thought that might fix it. --no... I'll give 2007 a try.. you would think I'd just get used to it.. but it irritates me every time.
