Question about Sony Playstation 3 (PS3) Console
PS3/TV Video Problem
When I turn on my PS3, it works as normal for a little while and then the video will freeze and many tiny discolored pixels will appear all around the screen.
I can still move around the XMB and hear the clicking noise, but the video will be frozen and nothing will appear to be moving.
I've tried resetting my video settings by holding the power button at start up, but that does not help.
  • 6,784 Answers
HI, this is an issue that concerns the main board. there is a integrated video card that is used to render the graphical information. there are some issue there with the internal connections. you will need to send this unit to Sony for this repair.
Posted on Jul 21, 2009
My ps3 turns on but no signal on the tv unless I have a disk in but then it freezes or I have multi color pixels on the screen I dont know whats wrong can someone please explain or help me
Are you using the HDMI video or composite or component? From your picture I would guess you are using HDMI. If so you need to go into the menu settings of the PS3 and selete HDMI out for the PS3 you may need to use your component cable to be able to get a picture on your TV to do this though. As another fault isolation test you may want to try the PS3 on another TV also to see if it does the same thing on another one...this would prove that the problem is in fact with the PS3 and not the TV alone. You may also need to reset your video if you have changed TVs or cable recently. While the PS3 system is in standby mode (red light on the front of the system), hold down the On/Off button on the front of the system for at least 5 seconds until you hear a second beep. The Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). Hope this helps!
Dec 27, 2014 | Video Game Consoles & Games
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
Freezes and pixelates
I've heard of systems doing this. I'm afraid your system is toast Gary. If it turned on an had error codes, or something was missing, you could fix it, but with the symptoms you described I think your main board is fried. The last time I've heard of they system pixelating, was when a system was not on a power strip and hit by lightning.
Feb 20, 2014 | Sony Playstation 3 (PS3) Console
How do i get the access code for epix.hd for ps3 console
I am having issues with mine same as most above.
I would like to try and reformat/restore settings but it freezes before i can even get the settings page.
Some times the tv doesn't even recognise that there is anything plugged in.
When i leave it for a while it loads up normally but then freezes.
with colourful pixels all over the screen.
Taken it apart, cleaned it still nothing.
i have fixed YLOD on it twice would this have caused something else to break?
it has worked since the last YLOD fix but its b*g*rd up now.
Any one got any solutions as to how to reformat hard drive if you cant turn the ps3 on?
Oct 30, 2013 | Sony Playstation 3 (PS3) Console
My ps3 turns on but nothing appears on the screen what should i do? i have all the cords plugged in
Your question is lacking a little information, but I assume you are using a HDMI cable. First you need to turn the PS3 on by the switch on the PS3. Then press and hold the On/Off button on the PS3, keeping it pressed until you here a clear beep and then a couple of seconds after you should hear a second beep. Once you hear the second beep take your finger off the button. Now as long as you are on the correct HDMI channel the rest should be on the screen for you to complete.
Please Note - If you have it working on a particular TV, then decide to unplug the PS3 and put it on another TV, there is a very good chance it will be blank again. This is normal because each TV has different setting, pixels, size, etc, and the HDMI has to be set to each individual TV. Once you get use to the settings. It takes no more than 1 minute to do.
Cheers, and hopefully this will solve your problem.
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
The screen freezes up when i turn it on
are the vents covered by blankets or a tight shelf? your PS3 is overheating.
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
Game or System freezing!!
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Nov 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation freezign at main screen
The "NO VIDEO/PIXELATED VIDEO/FROZEN VIDEO" problem is all too common on the PS3. It results from overheating of the RSX and/or CELL processor. let it cool and resume and pray
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 video output on SD tv is wavy with discoloration and black line
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
241 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
