Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
I need the exact size for bolts used in model 8800W
I need the exact size for the 4 gold long allen bolts (o), and 4 short Allen bolts with blue locking patch (P) for Simpicity "winnie-the-poo" crib model 8800W. They were lost and I need to replace them, I have a baby due in a month 1/2. Thank you
04 gold wing gl1800. There's an Allen bolt under engine next oil drain plug what is the Allen bolt?
Hi, Bill the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda GL1800 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1800 Owner Manual
Honda GL 1800 Gold Wing 2004
Honda Gold Wing
Jul 31, 2017 | 2004 Honda GL 1800 Gold Wing
I have the front of my 2007 Heriage Classic taken apart, but can't take out the screws on the bottom of the forks. What size allen wrench do I need? The wrnches in my set are either too big or l
Use a long 6mm allen to remove the bolts. Tap the centers of the allen bolts with a hammer and punch to loosen them before removal. I always use a butterfly air tool to remove them. Super easy! You'll want to replace the allen bolts and copper washers when assembling the forks.
Dec 18, 2012 | Harley Davidson Motorcycles
What size allen socket needed for cliper bolt on
CALL AUTO ZONE AND THEY SHOULD BE ABLE TO TELL YOU THE CORRECT SIZE.
May 07, 2010 | 1997 Buick LeSabre
One of the bolts fell out of the base of the MIII. I was able to tighten the lower two with an allen wrench. The one that fell out and the other next to it cannot be tighten with the same allen wrench...
I am not quite sure which bolts you are talking about, BUT if it is the 1/4" Base bolts then first remove them 1 at a time and loctite them to avoid them coming loose again in the future (Blue loctite). To remove/tighten the back 2 bolts, insert the long end of the allen wrench though the hole in the white base plate. Hook a 7/16" closed end wrench on the short end and tighten the bolt.
If you are refering to the two upper bolts on the magazine, then you must remove the 4 larger bolts from the base first. Remove the Base. Tighten the magazine bolts and re-install the Base
Oct 18, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
What size allen bolts are on the front brake
I think they are a t30 Not sure exactly, But ask the auto parts guy at the store he will be able to tell you exactly
Jul 12, 2009 | 1992 Chevrolet G20
I lost my instrction manual!
Step 1: Detach the front panel from the 2 front post using an allen wrench
Step 2: If the mattress support is not in the lowest position unscrew the bolts and move it to the lowest position
Step 3: Using the allen wrench, attach the guard rail using 4 bolts between the lest and right front post (the guard rail would be that extra piece that you couldn't do anything with while the bed was converted to a crib. Looks kinda like a wooden board)
Step 4: Tighten all screws and put the crib mattress back in
Apr 30, 2009 | Baby Gear
Front barke caliper bolts on 97 biuck leasbre what type and size
You will need to climb back there with a flashlight and look. I believe they are allen bolt, and they auto parts store will sell a kit with 3 of the most used allen bolts drivers in a 3/8" socket set.
Alternative is that the bolts may be torx, in which case, the auto parts store will have those as well.
The nice thing is, the sizes are very common, and the driver kit's normally have the 2-3 sizes that are most common for brake repair.
Jan 28, 2009 | 1997 Buick LeSabre
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
29 people viewed this question
Top Simplicity Baby Gear Experts
Greg Cann
Greg Cann
Jason Morris
Charles T Nevin
Charles T Nevin
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
