Question about Samsung SCH-U470 Juke Cellular Phone
I have a juke and the swivel around the ok button won't work
I have a juke and the swivel around the ok button will not work! THis means that in my music it won't switch from a playlist that i have back to all of my music! help please!
Why is it called jukebox?
"The term "jukebox" came into use in the United States around 1940, apparently derived from the familiar usage "juke joint", derived from the Gullah word "juke" or "joog" meaning disorderly, rowdy, or wicked" (Wikipedia)
Oct 27, 2013 | Audio Players & Recorders
Tip
Samsung Juke Buttons Fix
I have had a Samsung Juke and love it, but the ok button isn't working. There are 2 easy steps to fix any buttons that will not work no matter how hard you press.
1. Take out the battery and leave it for about 7 hours, it you can, write down numbers if you need to contact people. Make sure your phone is off when you take it out. If your end button won't work, wait for it to die.
2. Put the battery back in. If it didn't work, wait about 10 minutes. Than if it didn't work, report to your nearest Verizon Store to get it fixed.
on Nov 04, 2008 | Samsung SCH-U470 Juke Cellular Phone
OK button not working when pressed.
Most samsug have this general problem.
When ever you notice that your bottoms can function know that its a flex problem, Most slides phones always have alike problems.
Take it to the nearest repairer to change your flex.your phone will start functioning again. take care.
Jan 21, 2010 | Samsung SCH-U470 Juke Cellular Phone
Phone okay button doesnt work on my juke phone
Put 2 drops of alcohol on top of the OK button and let it run down into the button after removing the battery.
Sep 09, 2009 | Samsung SCH-U470 Juke Cellular Phone
The ok button wont work and it is locked
If some of the keys is not working, it really needs service.
Jul 01, 2009 | Samsung SCH-U470 Juke Cellular Phone
Get photos off broken Juke
you can also look on her phone to be able to send or uplload your pics by going off of her phone. if you know what i mean.
Jun 14, 2009 | Samsung SCH-U470 Juke Cellular Phone
My juke is broken the ok button wont click.. i dont know what to do a juke is a type of cell phone for people who dont know wat that is
it is the same for me. what i did was i took at the battery over night and put it back in. it could make it better or worse. after, bring it to the verizon store you got it from, or if you ordered online, any one.
Sep 13, 2008 | Cell Phones
Juke frozen, can't remove battery
I had the same problem. I would push the button and nothing would pop up. What I ended up doing was pushing the button, while wedging a pin in between the silver part and the colored back of the phone.
Sep 08, 2008 | Samsung SCH-U470 Juke Cellular Phone
Giga juke
Hi Koonjul. I have a similar problem with my Giga Juke occasionally, and the way I get around it is to power off (at the mains) both the server and the slave units. Switch back on the server and wait for it to connect to the network successfully. Then switch back on the slave unit and it usually reconnects to the server successfully. If this doesn't work, then switch them both off at the mains again and also power off the network router. Switch back on the router and wait for it to come back up completely. Then switch back on the server and slave units as above.
Jul 26, 2008 | Audio Players & Recorders
Sync music from my Mac to my Juke phone
Mac JUKE Solution ,I have 416 songs on my JUKE and here is how I did it. Plug your JUKE into your Mac ,turn it on , go to music on your JUKE ,scroll to <sync music> close your JUKE. Look on your desk top for <TELACHIPS> go to Applications then Utilities then Disc Utility. Open Disk Utility click on the <1.9 GB Samsung Drive Icon> select <partition> under format select <Mac OS extended Journaled> run the program . Now you have a Mac Drive an can drop and drag iTunes into the <music. folder inside the TELACHIPS icon . If you have bought music from iTunes DON'T put it on your JUKE it is locked and will screw things up! there are ways to unlock them, It's all on the Internet
Nov 16, 2007 | Nokia 1100
Samsung SCH-U470 Juke Cellular Phone Logo
202 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
