Hotpoint bwd129 how can i open the filter at
Hotpoint bwd129 how can i open the filter at the botton right hand - the water won't drain
  • tray smith Aug 08, 2013
    MY HOTPOINT WASHER/DRYER bwd129 1200 has froze, lights on right side are on + dryer light is on does is anyone know??
  • Washing Mach... Master
  • 3,463 Answers
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
Manual available as a download in PDF from Hotpoint website
Posted on May 23, 2010
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Oct 15, 2013 | Hotpoint Ultima WF860 Front Load Washer
Where is filter on hotpoint ultima
Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side and find the access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl say so if helped
Mar 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Bwd129 not draining
if your dishwasher is stopping on the drain cycle and not draining it could be a problem with the timer not kicking in to drain mode. or if it completes the entire cycle and not draining it is your pump thats bad. hope this helps.
Feb 22, 2013 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
I have a hotpoint WF840 error code F-05 how do I check pump for blockage and how do I empty machine of all clothes as door lock will not release?
remove drain hose from pipe at back and drain all the water in to a bucket or bowel this will take 2/3 goes then the door will open.your problem is the filter or pump is blocked check filter first its at botton of machine mbehind a panel it just pulls off
Mar 03, 2010 | Washing Machines
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint BWD129 stuck in rinse phase
Problem was caused by a faulty water temperature sensor. The clue was that the owner reported increasingly hot washes, then the machine stuck at rinse. A test resistor replacing the sensor allowed the cycle to finish. A replacement sensor is on order.
Jan 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Apr 03, 2008 | Washing Machines
Hotpoint bwd129
o k find the acess panel in the front or back then follow this procudure most likely there is something jamming the pump look on the back and you might see an access panel remove it and you will see a large hose coming down from the tub.Now the washer will still be full of water.There are three ways to deal with this the best way is to get a shop vac.remove the drain hose from the stand pipe and vac the water out,the second is to get a pair of radiator hose clamps from the auto parts store and clamp the large hose as close to the tub as possible ,the third is you can get a bucket remove the drain hose from the stand pipe and getting as close to the floor as possible let the water drain in the bucket .after that put some towels around the pump.Remove the clamp and slide the large Rubber boot off the pump look in the pump for foreign objects jamming the impeller blades and for broken blades if broken replace the pump.feel in the boot for same as pump .Then reassemble if nothing found then go check drain hose.
Jan 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
1,755 people viewed this question
Top Washing Machines Experts
