Question about Sony Playstation 3 (PS3) Console
My PS3 boots but nothing is on the screen
It worked fine until I took off the cable from the tv to put it on mah xbox and today it doesn't work...I tried AV cables also but nop nothing...and the most f'd up thing is...my 360 has a problem too and I am sending it in
  • marcos_rona Jul 21, 2009
    While its open or while its closed?Meaning...Do i switch it on and do it or switch it on, boot it up and then do it?
    Problem Solver:
  • 11 Answers
Try to hold down the power for one min it will reset the video
Posted on Jul 21, 2009
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
I toook my ps3 off my small tv and put it on my plasma and it was working fine with the hd chord in and then i took my ps3 off that tv and put it bak on my small tv and ever since that i cant see nothing...
There are series of problem in ps3 which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the ps3 repair guide that will help you a lot....
Click here to download PS3 repair guide
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
PS3 no picture problem..
Try using RGB cables and unplug the HDMI cable from the PS3, then while the PS3 is off, hold down the power button/sensor on the PS3 untill you hear a beep or a few beeps. This will force the PS3 to automatically detect the TV/cable resolution settings. Hope this works.
Aug 25, 2009 | Sony PlayStation® 3 (80GB) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Freezing at startup.
you tried it at the store and it worked fine but it still it wont work at home then. try this go to a diffrent tv in your house and plug it in to a diffrent power source get back to me and see if it works
Jun 14, 2008 | Microsoft Xbox 360 Console
Mitsubishi WD-52631no picture through the HDMI connections
had the same problem get a new cable its not the tv its the ps3 if the cable is tight in the ps3 it works fine or if you set the ps3 just right the cable will fit fine and work
May 24, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Ps3 unit stopped working
when on standby hold the power button for 4 seconds, it runs the optimal settings screen, i dont think this is your prob but it might help. What cable was used at your neighbours? was it an hdmi cable? did you knock your ps3 when moving it?
Feb 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
