Question about Gateway FPD1975W 19" LCD Monitor
Monitor seems out of focus because text has blatant shadows behind them. Hiw can I fix this? Thank you.
  • pstein69 Jul 21, 2009
    My monitor is not flickering as the last experts solution assumes. My monitor is out of focus. There are blatant shadows to the right of all text shown on monitor. How can I fix this? Thank you.
  • pstein69 Jul 22, 2009
    Reconnecting the cable worked. Perfect call. Thank you!
    Brigadier General:
  • 7,191 Answers
This type of shadows usually come up if there is some problem in either the monitor cable or the cable is not connected properly to the VGA socket of your computer. Please check the cable for any visible damage and also remove and reconnect the cable securely to the computer.
This should solve your problem. If the problem persists, your monitor might need servicing.
Also, it would be helpful if you provide us with additional details like:
how old this monitor is, any previous repair history, whether this problem is seen only in text or images too, and also whether the problem started suddenly or it developed gradually over time.
Thanks.
Posted on Jul 21, 2009
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
Please perform the following steps to find out if its the monitor or the graphics card which is causing this out of focus issue.
  1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
  2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
  3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Good Luck and God Bless.
Screen blue shadows laptop
See if you can set the sharpness a little lower in the monitor setup on the pc, not the monitor first. Then try sharpness on the monitor.
Mar 09, 2014 | Onda Computers & Internet
HP w19b "shadow"
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Sep 02, 2008 | HP Computers & Internet
Monitor ghosts & shadows
The LCD driver board may need to be replaced.
Have it checked by a qualified technician.
Mar 14, 2010 | ASUS MW221U LCD Monitor
Everything on the screen is blurry... not unreadable, but almost like there is a shadow behind everything.
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Feb 07, 2010 | HP Compaq FS7600 17" CRT Monitor
'Shadows' behind all texts and images on the screen
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
Feb 16, 2009 | HP L1706 17" LCD Monitor
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Double Images / Shadows on the monitor screen
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Problem with monitor
Shadow after text is usually caused by an impedence or termination issue. If you have a multimeter, check the VGA connector pins 1 2 3 (R G B) vs GND should be 75 ohms. If not, cable is damaged or poor quality. Try a new VGA cable, should cost $5+
If the edge of the text is wavy, there is too much jitter in the signals coming from the graphics chips. No fix possible.
If the edges of the characters are lumpy, then the panel has a cheap A/D converter, try using it in DVI mode instead (white-white connectors instead of blue).
Nov 15, 2007 | Computers & Internet
Problem with shadows showing on monitor
The solution to this is very simple. No software or hard ware changes required.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
