Question about Whirlpool Dryers
Dryer won't heat up and it won't shut off automatically
    Problem Solver:
  • 15 Answers
The dryer timer advances when the temperature sensor hits a preset level (or the moisture sensor detects the clothes are dry if your unit is so equipped). If your dryer is not heating up - it is normal for the timer not to advance. Check the easiest things first - assuming this is an electric dryer, make sure that both sides to the circuit breaker are not tripped. Electric dryers use 220 volts for heating, but only utilize one pole of this (110 volts) to run the motor. A dryer can "run" without heating if one pole of the 220 volt circuit is blown. Next, check your heating element. A visual inspection is easiest, but you can check with an ohmmeter (make sure the unit is unplugged). If the element is good, I would next check the limit thermostat (you could temporarily bypass as a test - but DO NOT run it that way as this is a crucial safety feature). Another culprit is the centrifugal switch on the motor. This switch only allows power to the element if the motor is running - but if the switch goes bad - no heat. Always - always -always - make sure your vents are clean and flowing freely - a restricted vent is a fire hazard and leads to overheating which is likely what caused the components to fail in the first place....
If none of these are out - write back and I will try to give you more ideas...
Posted on Jul 21, 2009
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
The dryer works and heats up but it won't shut off
I believe that your timer has run out of time! ;) Seriously though, Your problem is more than likely your selector (the dryer timer knob) is worn out. Time to replace it with a new one.
Good Luck my friend!
Phillip
Dec 27, 2011 | Whirlpool Washing Machines
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Heat comes on and heats the drum, then it shuts off but doesn't come back on.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 01, 2010 | Kenmore 400 6943 Dryer
Does not heat, automatic timer when out first
heatman101
Jul 17, 2010 | Kenmore Dryers
No heat during either drying cycle automatic
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
I have a whirlpool dryer that will spin but will not heat or shut off automatically?
some dryer 's have belt sw on them if belt breaks dryer stopes ( no spin ) if dryer stops no heat . replace the belt and it should work .. other problems / ck the power if 220 you may have lost 1 leg . dryer will go but heat and will not shut of auto . mm
Dec 09, 2009 | Dishwashers
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Dryers Logo
1,041 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
