Question about Black & Decker Drills
The drive cog that sits on the spindle in the main hand piece of my Black & Decker 4 in 1 is missing which means when i attach one of the heads it does not operate. Can i replace the drive cog?
    Sergeant:
  • 384 Answers
Yes.
Posted on Jul 21, 2009
I have a black and decker CS1000. How do you tighten or loosen blade. There is no spindle lock that I can find.
If you can't find a spindle lock you can unplug the tool and find a piece of wood and put the blade against it and loosen and also tighten the blade, but most newer saws have a spindle lock located in the gear housing somewhere.
Sep 18, 2011 | Black & Decker CS1012 7-1/4" 12 Amp...
How do I remove drill bit?
Your drill uses a key less chuck (the part that holds the drill bit). Grab the black spindle just below the drill bit and turn it clockwise when facing the drill from the back. Some drills have a locking chuck and only need to turn with one hand. Other drills don't have this option and use a 2 piece chuck. If it looks like there are 2 parts to the spindle, you will need to hold the the back part with one hand while turning the front part with the other hand.
Hope you find this useful
Mr Tin Man
Dec 29, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
CST2000 can't get the battery off when pushing the two release buttons.
Black & Decker didn't make it easy to remove the battery pack. You have to push both buttons in at the same time, while pushing the battery pack forward. It takes a little while to get good at it -- you have to hold onto the trimmer with the same hand that's pushing the buttons in, while pushing the head forward with the other hand.
If you're only taking the head off to charge the battery, you can charge it while it's still attached. The hole for the adapter is on the back of the head, so you can plug it in while it's attached to the trimmer.
Hope that helps!
Jun 17, 2010 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 4 1/2 grinder gets very hot when in use
You will see vents near the head of the grinder. Make sure your hands are not blocking when in use. Also another thing I like to do with my grinders is removed the head cover (gear box) and replace the lube with a good grade of grease. I suspect if you open yours it will look like an orange wax substance. Clean and re-lube. They do run on the warm side.
Jun 09, 2010 | Black & Decker 4 1/2" Small Angle Grinder
Need replacement beaters
Black & Decker MX77 PowerPro® 220 Watts Hand Mixer Black & Decker MX77 PowerPro® 220 Watts Hand Mixer - User Rating: 4 stars. ... There are no signs of rusting around the metal parts. Overall ...epinions.com/review/pr-Black_Decker_MX77_Mixer/...
Nov 02, 2009 | Black & Decker 220 Watts MX77...
Describe your Black & Decker
You have missed a screw about half way, there is one under a sticker.
Sep 03, 2009 | Black & Decker 14" Grass Hog Xp...
I have a Black & Decker B2200 bread maker on which the spindle has dropped out of the bottom of the bread pan. It looks as if O ring is missing between the spindle and the collar it passes through....
I just bought a new b2250 machine from Zellers for $59 dollars, they also have the b2000 for the same price. It's not worth your time to mess around trying to fix these things.
Jun 22, 2009 | Black & Decker B2250 Bread Machine
Black & Decker GL720 Strimmer not working
Hi there, I just thought I'd mention that I also have a Black & Decker GL720 with the same problem. I'm pretty sure it is less than 1 year old too, so well within the 2 year manufacturer's guarantee here in the UK. I think it may be a UK specific model and the phone number from MrFixIt looks like a US number.
I have tried taking the plastic casing apart, but with no luck, as the two halves won't come apart easily, even after removing all the screws. Ah! OK, I've found out the reason that it wouldn't come apart now, there is a screw hidden under the 123 sticker.
It's all apart now, and I see what is wrong, there is a belt running between a small cog and a large cog, and in my case the large cog has partially melted and the belt has come off. Unfortunately, I'm not sure I can get the replacement part now. Hopefully with yours, MrFixit, the belt might have just slipped off, fingers crossed.
Anyway, here is a service diagram of it in case it will help anybody, but as you will see it says only certain parts can be ordered. If anyone locates a supplier of all the parts please post it here.
Many thanks
Simon
Apr 19, 2009 | Black & Decker String Trimmer Cordless 12"...
Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
Sep 10, 2007 | Philips Philishave Cool Skin HQ6760/HQ...
Drills Logo
47 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
