Question about Carrier 38CKC030 Air Conditioner
Problems with the fan are one of several things to consider.
1. Is their power to the fan motor.
2. Does the capacitor for the fan hold a charge and/or discharge (There are metering devices that can identify the condition).
3. Are the fuses blown (If Applicable)
4. Is the breaker to the condenser tripped.
5. Are the windings on the motor closed or open.
6. Are the winding (when using an Ohm Meter, Check the resistance from ground to one of the lead wires, making sure power is disconnected and all leads are disconnected from the terminal points. There will be high resistance if there is not a short from the windings to the frame ground.
These are simple checks I make to determine the motors condition. Sometimes a wire does come loose or cut or even burned. I trace the wire from point A to B and also making sure the wire terminal connections are tight.
Posted on Jul 21, 2009
SOURCE: 38cks is blowing air but it's not cooling
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
Posted on May 21, 2010
SOURCE: I have a Carrier 38CKS
Sounds like your fan motor is going out keep an eye on it it could just have been the first start of the season. The unit does sit there all winter not moving. If this continues replace fan motor and capacitor. If this helps please rate me and do a testimonial.
Posted on May 23, 2011
Sep 04, 2014 | Heating & Cooling
May 23, 2011 | Heating & Cooling
Jan 19, 2011 | Heating & Cooling
May 21, 2010 | Carrier 38CKC030 Air Conditioner
Jul 18, 2009 | Heating & Cooling
Apr 18, 2008 | Bryant 463AAC008BA Air Conditioner
Oct 05, 2012 | Carrier 38CKC030 Air Conditioner
281 people viewed this question
