Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
I have a hannspred 22'/HF229H, and i can't get the picture to not be in a stretch mode. this ruins the fun of looking at my vacation pics. i followed the advice of one solution tip - go to menu,then image settings and then change from HDMI mode to PC mode. that is not an option on the image settings menu. any other suggestions?
    Problem Solver:
  • 6 Answers
Try this driver for Hannspree HF229H:
http://rapidshare.com/files/401122732/HF229H.inf
Posted on Jun 20, 2010
I have a Bradford white water heater- how do I check if it is on vacation mode?
The gas valve dial, which is in front of the heater near the bottom, will say "Vacation" mode. Just line up the pointer with the word vacation. Some models no longer use the word "Vacation", replaced with "Low or Warm". It will be the setting just before "OFF"
See Pics (inside blue box) answers your questions:
Feb 13, 2015 | Water Water Heaters
Can I take semi full memory stick out, replace with a new one, & deal with saving & printing those pic's later? I am not sure what I am doing & going on vacation & need to beable to take...
Absolutely! That is the wonderful thing about digital cameras. You can buy as many memory cards as you like and if one gets full, put in a new one. Usually when you buy a new memory card it comes in a plastic lock casing. These are great to save, to keep your already-full memory cards safe.
Have fun on vacation!
Please let me know if I can help you further.
Regards,
KYTechnology
Mar 02, 2011 | Akai Cameras
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree will not supply XP drivers
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Get pic slideshow when i try to open camera mode
on the top left hand side of your phone there is a slide button. I believe yours is slid to the bottom, the third option. That makes the slideshow appear everytime you open the camera option. Slide it all the way to the top. That is the camera option. The middle one is the camcorder
Jun 18, 2008 | LG KU990 Viewty
DRIVER ISSUE
THIS IS FROM ONE OF MY OTHER POSTS THIS WILL WORK WITH ANY MONITOR TO MY KNOWLEDGE AND SHOULD FIX THE PROBLEM.
Ok so i was searching around the internet and found a similar problemwith another monitor so for giggles i tried there method. This is thewebsite where i found it : http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/d7c0e5bd-2fcf-48ff-a79b-c157014fc821/#page:3
The Secoind wntry has a download.Download it then extract the files to the desktop. Dont worry if youget errors when the program runs it will fix them, if they come up justpress enter to keep going. Once the program completes install thedriver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
http://www.portrait.com/dtune/hpw/enu/support_help.html
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
http://download.portrait.com/DRVFix.zip
Download DRVFix.zip. The fix contains 3 files including this readme. All must be in to the same folder.
  • readme.txt - This file
  • RestoreDisp.exe - Executable required to restore permissions. DO NOT RUN THIS FILE
  • DVRFIX.exe - Run this file in Administrator mode after reading the instructions completely
To perform the fix do the following:
  1. Extract all files in to a folder on your desktop
  2. Open the folder, right click on the DVRFIX.exe file and choose "Run As Administrator"
  3. Follow the on screen instructions. When complete, you should be able to install your drivers
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
Regards
Vesa"
There you Go, KD0BGA
Apr 12, 2008 | HP w1907 LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
557 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
