Question about Numark DM1200 DJ Mixer
THIS IS NOT A NUMARK. need help with denon x120
What crossfader should I get to replace the stock fader in my Denon X120?
And is it possible to fix the stock one? It intermittently bleeds through 100% when it's all the way opposite of the channel making noise.
    Problem Solver:
  • 11 Answers
I like the Pioneer DJM-600
Posted on Jul 21, 2009
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
Jul 09, 2016 | Numark Music
Fix p+g faders on mackie control
You might call mackie for a suggestion at 800-258-6883. Sometimes there may be older parts in stock at other Mackie distributers around the world. Here's a list of contact info Mackie International Distributors It doesn't hurt to ask and email is free!
I had good luck getting parts for various musical electronics out of Canada
Feb 01, 2015 | Mackie Music
I Bought the Denon Mc2000 Dj Controller, The Place Where i dj has its speakers coming with 2 RCA cables to plug in plus I have to bring one of my Amplified speakers(JBL EON 15'')... I have tried al...
you are getting reverse polarity, meaning the speakers on one is the opposite as the other, black>red red>black, thus only getting vocals or music.
Oct 18, 2013 | JBL Music
How to connect denon sc2000 to external speakers
As far as I know you can't. You'd have to connect it to a mixer or USB device and use the MAIN OUT (or equivalent) on either of those to connect to external speakers. The denon sc2000 isn't meant to be something you'd use to listen, more to route and control.
Apr 29, 2012 | Denon DN-SC2000 MIDI CONTROLLER DJ MIXER
HOw do you use the crossfader if all your music is coming through one port???
The crossfader is to gently fade from one source to another. If you only have one, the crosfader isn't useful... it would act like a plain fader with one side being dead and the other at full volume.
Aug 06, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
The Crossfader does not work. I just bought it. I don't think it's broken even though everything else works.
Exactly the same thing happened to me think they send them out like it so you get the info fader upgrade I took out the two screws popped the fader out it was cruded up so I sprayed contact cleaner in to it.Just to clarify you have it set up right if your using it just with software you need the in on chan 2 out on chan 3 on the front and make sure the curve is set right
Mar 28, 2011 | American DJ VMS4 Digital DJ Work Station
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
I have a Numark C2 19" mixer. I am missing one of the small screws right next to the crossfader and need some replacements. Where can I get them and/or what size are they so I can buy them at my local...
They are LIKELY metric and the best way is to remove another and take it as a sample to a hardware store.
Use a nut to find the correct size thread and then find the matching screw and right length.
Jun 11, 2010 | Numark Avm02 Audio/Video Mixer with...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I want a denon repair manual for avr 1000,or any manual showing block diagram of avr-1000,help me please
These are only available from Denon directly. I'm not sure if they will sell them to the public. We used to get them as a Denon service center.
What is the specific problem you are trying to resolve? Perhaps with a description we can guide you through the repair.
Dan
Apr 15, 2010 | Denon Music
Numark DM1200 DJ Mixer Logo
121 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
rhodesworks
Are you a Numark Music Expert? Answer questions, earn points and help others
