Question about Sony Cyber-shot DSC-W120 Digital Camera
My lense is stuck open despite turning my camera off. On turning my camera on I am told ''turn camera on off then on'' but the lense does not retract. I am able to view all photos on the memory card as well as turn the camera on and off, however at each point when the lense should retract it stays fixed out. Can this be fixed?
    Brigadier General:
  • 4,090 Answers
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
Posted on Jul 26, 2009
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
The problem is when i switch my camera on, on the
ok so I was searching for the answer for this myself.. very hard to say, because it really depends on what happened to your camera.. Did you drop it? Did it emerge in water? But for me, I have come to the conclusion for everyone who has the problem.. it is most (99%) probably a problem with the lense.. another site told me to take it to get fiixed- or to take the battery out and wait 20 min to put it back in, because this resets it. I decided to manually open the lense myself (who knows if thats bad/good to do, but a girl's gotta take her pix!!) So anyway, i opened the lense, and turned it on- the "on again off again" msg went away. So most likely, the problem does stem to the lense not being able to be opened, so the msg pops up, if you open the lense yourself your camera works fine, when you turn it off- my closes the lense-just doesnt open it. different results for different people, but i hope this helps because it was very simple.
Feb 04, 2010 | Samsung NV4 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Lens is stuck open/extended
Im having the same problems with mine, I can view my pictures, but the lenses is stuck out, beeps a few times and then I get the E18 error. I tried everything at http://www.e18error.com/repair.html but still no luck, ready to take it apart and see what is stuck
Aug 20, 2007 | Canon PowerShot S2 IS Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
313 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
