Question about Asrock P4I45GV R5 Motherboard
I want to increase my graphic memory 128MB to 256MB. My system memory is 2GB, graphic card memory is 128MB and my graphic card is nVidia Geforce 7100 GS. Can I do that?
  • 1,511 Answers
Yes why not, you can upgrade it to 512 even. But there are few things to check first. 1) Check your board got PCI-E slots or not (I guess this board doesn't have any)
2) Then you should have an AGP (Advance Graphic port) (Where you have attached this Card)
3) Check the AGP speed (2x,4x,8x)
4) Usually the AGP cards (The newer ones) are (4x,8x) compatibility.
Then Your board should have atleast 4x AGP Slot. I remember a software "Sis Sandra Pro" to check the AGP speed.
Afer checking and confirming these things, go to a shop and but a graphic card, (Which falls in the catagory i described above).
Better go for nVidia brand. But let me advise you, You should shift yourself on the PCI-Express PC's. On those PC's you can enjoy some gaming experience.
If i was helpful, kindly do Rate!
Posted on Jul 21, 2009
  • Waqar Hassan
    Waqar Hassan Jul 21, 2009
    You can not increase you shared memory, its at max 64Mb for this board.
    I checked the Specs of your board, you got an AGP slot not any PCI-E so just goto stp 2 ie; Check the speed of your AGP Slot, through Sis Sandra Pro, or if you got the manual it should be mentioned there.
    Most probably it would be 4x. (But confirm it, it it is so then;)
    Buy a AGP Graphic card, which should be compatible with 4x-8x slots (It will be printed on the Box).
    If you got any more queries, don't hesitate to reply.
    Regards.
  • 374 Answers
You are talking about double the memory and it's impossible,you'll have to buy a new graphics card for that much memory.System configuration doesn't matter...your graphics card won't be able to take it. I would suggest you to sell it to some friend and buy a new one...that'll be easy on your pocket also.
    President:
  • 948 Answers
The way you increase your video memory is change your video card. With an integrated graphics chip on a motherboard you can increase the shared memory, improving the graphics performance up to a point. With a dedicated video card the slowdown caused by data transferring between the video card and the main computer RAM would offset any potential gains from having more memory available.
The good news is there are many video cards available that have more than 128Mb of RAM. You can even get them with 1Gb or more. Make sure and get one that matches your motherboard's interface. Most likely that is PCI-E, but check your documentation or the Asrock website to be sure.
I have purchased a asus p5g41c-mlx motherboard on jauary 2011 .but after 2 month its grahpics not work properly ,it is flickering ,i have using window xp. i have uninstal the grahpics and reinstal it but...
Hello there,
Here is *********** boards VGA details.
Integrated Intel GMA X4500 graphics Maximum shared memory of 1GB
Supports RGB with max. resolution 2048 x 1536 (@75Hz)
Supports Microsoft® DirectX® 10
Here are the system requirements of the games you are currently playing with problem.
NFS Most Wanted- It should run with no problems just avoid high detail settings.
Minimum: 32MB or more, ATI 7500 or greater; ATI Radeon Xpress 200; NVIDIA GeForce2 MX/GTS or greater Recomended: NVidia 5900 or ATi 9800 with 256mb of video memory
Prince of Persia Two Thrones
Minimum: 64MB Recomended: better than recommended in NFS Most Wanted
COD Black Ops
Minimum: Shader 3.0, 256MB GeForce 8600GT/ ATI X1950 Pro or better. Recommended Nvidia: GT 240 or higher Recommends Ati: HD 4670 512MB or higher Minimum Memory: 2GB
Some games have hardware validation test if your unit fails to the requirements you cannot install the game. try to download this BurnIn. Select the 32bit Standard edition. install the utility and stress your x4500 graphics. Sir you did not post your Processor and Memory. The x4500 graphics will use 128MB of your ram, If you are using 1GB or 1024MB - 128MB = 896MB. 2GB or 2048MB - 128MB = 1920MB. For Memory system requirements your system failed and the main problem is your video card.
Hopefully this helps.
Thank you for using FixYa.
Jul 22, 2011 | ASUS Computers & Internet
I have a nvidia geforce fx 5500 graphics card which says it has 256mb available memory,and it says total video memory 256 mb,shared video memory n/a ,shared video memory n/a, and when i try to play age of...
You will need to install the latest drivers for this card. Go to the Nvidia website and select the relevant options from the drop down menus.
Product Type: GeForce
Product Series: GeForce 5 FX Series
Product: GeForce FX 5500
Operating System: The operating system you are using
Language: English (US)
Then click search
It will then take you to the download page.
If this dowsn't work then make sure you have connected your monitor to the FX 5500 card and not to onboard graphics.
Jan 14, 2011 | Palit Microsystems GeForce FX5500, (256...
Hi sir i have asus p5 nmx having nvidia geforce 7050/nforce610i integrated graphic .it shows 390 mb total graphic memory in win 7with 1 gb ram .where it shows 780 mb useable ram .here i have chosen 256 mb...
512 for 2gb and 780for 4gb
in intergrated gpu,s the memory is borrowed from the main system memory however the actual intergrated gpu has some of its own memory,but this is normally only small such as 64mb or 128mb however it can borrow memory from the main system memory,something thats known as s.m.a(shared memory architecture)
there are also some dedicated graphic cards that borrow memory from the main system memory,these are known as "turbocache" with nvidia based cards and "hypermemory" with ati radeon based cards,however these cards are very rarely used now as they were not that efficent and in windows vista they score very low performance baseline scores
Nov 13, 2010 | Computers & Internet
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Increase graphics card memory
go to your bios setting > chipset feature > onchip AGP.
you can increase your Graphic card from ther if it is on bourd.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
I want to know of a graphics card that supports vista graphics can play fallout 3. this card needs to be for agp x8 and under $50 can you help???
Minimum requirements
  • Windows XP/Vista
  • 512MB System RAM (XP)/ 2GB System RAM (Vista)
  • 2.4 Ghz Intel Pentium 4 or equivalent processor
  • Direct X 9.0c compliant video card with 256MB RAM (NVIDIA 6600 or better/ATI X850 or better)
Jan 20, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Nvidia NVIDIA GeForce FX5500.
hi raul,
In order to download the drivers for the FX5500 you need to visit
http://www.nvidia.com/Download/index.aspx?lang=en-us
At this website you need to adjust the following parameters:
Product type - leave at GeForce
Product series - set to GeForce 5FX Series
Operating System - select the OS you are running on your PC
Language - Select the language you prefer
click Search
on the next page click Download Now
I hope you find this information helpful in solving the problem.
Please take the time to rate this solution.
Kind regards and thanks for using the FixYa service.
Mar 23, 2008 | Nvidia GeForce FX5500 128MB DDR AGP Video...
New graphic card
ya go for it it will may lower card specks if u have any limitations but your ok agp 8x 4x slot
Jan 24, 2008 | Computers & Internet
Graphics card
In order for Cold Fear to run properly, your PC must meet or exceed these minimum requirements:
Opertaing System: Windows 2000 / XP Only
Processor: 1 GHz processor minimum, (2 GHz recommended)
RAM: 256MB RAM minimum, (512MB recommended)
Video Card: DirectX 9 compliant 64MB (128MB recommended) see supported list *
Sound Card: DirectX 9 compliant
DirectX Version: DirectX 9 included on disk
DVD-ROM: 8X or better
Hard Drive Space: 2.2 GB
Peripherals: Mouse, keyboard, Windows compliant game pad.
* Supported Video Cards at Time of Release
Nvidia GeForce 3/4/FX/6 series (GeForce 4 MX not supported)
ATI Radeon 8500/9000/X series
These chipsets are the only ones that will run this game. Laptop versions of these chips may work but are not supported
NOTICE: This game contains technology intended to prevent copying that may conflict with some DVD-RW and virtual drives.
Also, make sure that no other programs are running.
Dec 09, 2007 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
671 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
