Question about Toshiba TLP S30 Multimedia Projector
Toshiba TLP XD-2000
I have a Toshiba TLP XD-2000 and when it is connected to my computer, a series of lines scroll across the projected image from top to bottom. I have swapped every cable and the refresh rate is correct. What do I do?
There are two things it could be...
First, how far are you trying to run the cable for? When you run longer distance a humbucker might be needed. Or it means that the internal distribution output has bad vertical and horizontal connections.
Posted on Jul 24, 2009
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Video Projector from Toshiba
I think it might be the video player or it might be the computer settings and the projecter settings.
Jan 06, 2009 | Toshiba TLP-S10 Multimedia Projector
No video picture
It might be the projecter settings or the setings for you viedio player. One other thing is that itt could be the computer setting you have.
Jan 04, 2009 | Toshiba TLP-S10 Multimedia Projector
Problem with image from LCD
No, If the problem comes with connecting the signal, then it could be RGB.
if this is coming with all time then check LCD panels and Fly-eye lens.
Last thing is lamp unit.
viren
Sep 19, 2008 | Toshiba TLP-S10 Multimedia Projector
Out of focus...
http://www.projectorcentral.com/pdf/projector_manual_1798.pdf.
please read manual above.
Oct 25, 2007 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
242 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
