Question about GE Spacemaker JVM1640SJ Microwave Oven
The keypad buttons do not work
Just moved into a house with a GE spacemaker and the buttons are nearly unresponsive. Pressing "time cook" doesn't do anything. The only buttons that work and only occasionally are the express 1 minute, 5 minute buttons. The only way they will sometimes work is periodically unplugging the microwave and resetting it. Please help
  • sabrinacaseb Jul 26, 2009
    It is a GE - The model number is JVM1640WJ03 and serial #LH900170U. Right now the only way it works is by unplugging it and replugging it in immediately before heating. If it is left idle too long- no buttons will respond. I'm wondering if it is on it's last leg and worth the investment?
  • William Miller
    William Miller May 11, 2010
    You have a failing membrane keypad.
    If and when an oven is coming on or doing anything by
    itself, this is very dangerous and can result in a fire.
    So until it is repaired,
    please leave it unplugged or leave the door
    open when it's not in use, and please do not leave it running
    unattended.
    Please reply back with your full model number from the tag inside the unit so we can help you and give you a cost estimate.
  • GE Master
  • 9,085 Answers
> model JVM1640WJ03
The keypad is part number WB27X10721 MEMBRANE KEY PANEL available for $37.09 here (it's $61.50 from GE!).
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
First of all, you should check the end of the keypad strip for rough white, gray, or green deposits that can sometime interfere with conductivity.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then disconnect the strip as shown in the photo below and use a soft pencil eraser to gently clean both sides of the end, then reinsert it and try it again.
If that doesn't fix it, and you don't notice any rough white, gray, or green deposits on the circuit board (moisture or mineral deposits) or grease, then your keypad is bad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 26, 2009
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker microwave, Model #JVM140H 002, manufactured March, 1990. Sometimes when it is cooking, it switches to a "timer" mode. Other times, I cannot get it to cook - it just goes to...
The problem is in the keypad controller, the microprocessor is mounted on a circuit board along with other parts behind the keypad. Now if this can be repaired it will come down to the availability of a replacement keypad module, you would need to check with the manufacture to see if they carry any stock and price. There might be a possibility that a appliance repairman or tv technician may be able to repair the module if replacement is not available.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Paper caught fire in microwave. microwave power
check breaker in your home electrical panel...make sure all are on
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Micro stopped working
Try looking at the microswitches behind the door.
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Over the Range Microwave/Convection won't start
So it's dead - that is to say no display, no lights, and no response from the keypad?
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
403 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
