Question about Norcent Technologies E-DVKIT003 10.2 in. Portable DVD Player with Screen
Need replacement battery pak DC 7.4v, E-DVKIT003
Can SimpleTech runs on 220 voltage
Not enough info.....
Ask Simpletech. I Dont use simple tech brand but it usually is similar to other products.
Most Hard Drive Boxes are connected to a Power Pak that goes into the AC wall outlet to drop the power down to low DC voltage.
Most power pak's handle 110 & 220 ac these days. Read the tiny writing on the power pak label. It's usually marked as input & output.
Good Luck
Oct 17, 2014 | SimpleTech Simpledrive Computers &...
I need to know how to charge a marlboro power pak in detail
There are two different ways. You can use either an AC outlet in your home, or a DC outlet in your car (cigarette lighter). Your battery may be dead inside the unit, as these particular power packs are notorious for battery failure. I've had to put two in mine since I've owned it. You can get them on eBay for about $13.
Sep 24, 2009 | Electrical Supplies
Ever since buying a "re-Chargable" battery pak for Wii Fit it takes off more weight than should be (approx 3.7KG more). The Wii Fit has been working great up until the Battery pak. Strange thing is,
If you're using the Wii Fit on carpet, you need to use the additional legs that came in the package. Simple pop 'em on and they should (hopefully) fix the problem.
May 24, 2009 | Nintendo Wii Fit for Wii
Compaq v2000 laptop burns out power supplys
You have shorted DC connector in laptop.
It needs to be replaced. Very common problem.
Mar 26, 2009 | HP Compaq Presario V2000 Notebook
AC Adapter
You can buy a new NORTECH MEDIA E-DVKIT003 wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for NORTECH MEDIA E-DVKIT003 PORTABLE DVD PLAYER
Mar 13, 2009 | Televison & Video
My battery won't charge on my Nortech E-DVKIT003 Portable DVD pla
You may need a new battery. How long have you had this one?
I hope this solution helps.
Feb 11, 2009 | Durabrand PDV-709
Missing power cord
You can get an after market ac adapter charger for the E-DVKIT003 dvd player here.CLICK:
AC ADAPTER E-DVKIT003
Dec 19, 2008 | Durabrand PDV-709
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
Nov 22, 2008 | Nintendo 64 Console
Controller Pak Abnormality???
Sorry evilpacman, but you're wrong.
The N64 Controller Pak does indeed have SRAM as you state, but SRAM _does_ require a battery to retain its contents. The battery in question is a standard CR2032 or "coin-cell". The only gotcha is that it is a PCB mount variety, with the legs already attached to the battery casing. I'm currently looking for a replacement myself... farnell may have them but I need to check the footprint...
Jul 13, 2008 | Nintendo 64 Console
Norcent Technologies E-DVKIT003 10.2 in. Portable DVD Player with Screen Logo
259 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
