Question about Technics Audio Shelf Systems
Technics sc-ch7 i purchast this set up new but require the circuit to repair a majour fault
0 characters
1 Points
Looking for an panasonic stereo system model# sc-ak630 new or used.
Please try your luck at the following link:
However it is ideal to search around the repair stores in your area to find one if you are lucky.
For new set log on to the Panasonic website.
Jul 23, 2011 | Panasonic SC-AK630 CD Shelf System
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
Burnt resistor on primary side of transformer on pw po:2437473 i would like help identifying resistorf
1. discontinue use momentarily, by disconnecting on periperal energy devices.
2. perform a physical observation to determine extent to damage, before contacting technical support specialist. required information includes device kinds, model specifications and description of the fault.
advice technical support is the most convenient alternative device malfunctions considering, expertise requirements, possible manufacturers specification details recognisabel by technical installment entities.
Dec 01, 2010 | Philips Audio Shelf Systems
Technics manual sleh600
Technics SL-EH600 is CD changer, which is part of SC-EH600 syste, so download:
SC-EH600 Manual, scroll to pages 18-21 for SL-EH600.
Feb 24, 2009 | Technics SCEH790 CD Shelf System
Where can i get service manual for my Technics sc eh760/790
I believe that these units use amp-pacs which look like large black ICs with multiple pins. If you can post the model number of the main unit, I should be able to get you the part number and cost. The model you list is the system model and I don't have a cross reference for those.
Feb 16, 2009 | Technics SCEH790 CD Shelf System
I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at:
Feb 06, 2009 | Panasonic Audio Shelf Systems
Switching off of SA-AK-37 Music system
Do you have the manual, I think panasonic put some of there fault codes in the back.
Seems to have lots of people saying it could possibly be a power supply fault, an amp fault or shorted speakers.. Some people have gone to the extreme of actually buying new components and trying to unsolder and resolder to try to fix it themselfs.
Try contacting Panasonic, they will be able to advise you better ot possibly repair / replace the system.
Jan 31, 2009 | Panasonic SC-AK200 CD Shelf System
Missing manual
You can download a manual from link below:
System Component SC-EH790 SC-EH590
Do not forget to rate the solution.
Jan 29, 2009 | Technics SCEH790 CD Shelf System
Technics seperates
I'm not familiar with the exact system you have but the simplest cause to this problem woulf be a sticky switch, since power is reaching the system for the stand by light to come on.
It is possible to test switches like this by opening up the stereo and touching an unbent paperclip across the two metal contacts that go into the switch. If it comes on then you know your switch is bad, however be warned that running electrical equipment with the casing off puts you at risk of receiving a shock if you touch the wrong part so I don't officially recommend this.
If the switch is faulty then you can either try cleaning it by spraying a contact cleaner such as IPA into it or just replace the part (though this will require soldering).
Otherwise, some stereo systems have an internal fuse that will blow to protect the circuit if you overload it so have a look for fuses on the circuit board.
Nov 27, 2007 | Technics SC-EH780 CD Shelf System
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Audio Shelf Systems Logo
641 people viewed this question
Top Technics Audio Shelf Systems Experts
Are you a Technics Audio Shelf System Expert? Answer questions, earn points and help others
