Question about TruTech PVS31170S1W 17 in. LCD Television
How do I correct a "Bad Disc" error for every dvd I put in player
I have tried cleaning all the dvd's and the player itself it still
gives me the same message "bad disc"
  • 188 Answers
Replace laser unit or check power supply 5 and 12 volts for the DVD part.
Posted on Jul 22, 2009
I have a Cyberhome 300 DVD player and whenever I put in a disc it will say loading for 2 seconds then gives me the message of no disc. I took the outer casing off of the player to reveal the drive itself...
Good day!!!
That problem is cause of dusty or defective optical cd lens..
please try to clean it the lens or replace it to fix your problem..
if you need specific solution and more help...Please try to click this "
Fix No-disc error on DVDs" and try to purchse my service..
Thank you for using fixya..
Oct 06, 2011 | Cyberhome CH-DVD 300 DVD Player
When i put in a disc, it always says "disc error" , even on a cleaning disc. i have tried dvd-r, and dvd+r
I would NEVER use a cleaning disc as they tend to be abrasive and to be honest only any good for much older models where the laser is directly over the disc.
Most of todays models use mirrors etc so this does not clean the laser itself.
I would be looking at replacing the laser head or having it done by a pro as they are easy to pooch if you dont have the correct equiment
Aug 17, 2010 | JVC SR-MV30U DVD Recorder/VCR
No disc error even with DVD inside the player
I am sure that you have tried using another DVD.
Try putting a Music CD and see if it can read it.
In any case, even if the CD works, it looks that you have a faulty unit the laser on the drive is probably bad now but just in case it is just dirty, try to clean it with a Cleaning Disk and see if the problem disappear.
Dec 23, 2009 | Kaser Corporation Mambo BW MP3 Player
DVD gives an invalid Disc Error
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
Mar 30, 2009 | Lite On LVC9006 DVD Player/VCR
DISC ERROR
it could be a region problem. most dvd players are locked on certain region areas..like America being Zone 1 and S.A being Zone 2. imported or diffirent format of dvd's usualy gives a disk error message. if you think it might be region try www.videohelp.com. they give hacks for region problems^^
Mar 30, 2009 | Sony RDR-GX300 DVD Recorder
DVD won't load classifys all discs as bad
Have you tried cleaning the heads with a VCR head cleaner tape?
Feb 27, 2009 | GoVideo Go Video DVD/VCR Combo
Portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Nov 27, 2008 | Televison & Video
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
Bad Disc
Try using a lens cleaner and see if that resolves the issue. Also see if this error occurs with all discs or just a particular one. If it happens with all discs, then it is a lens problem. If it happens with just a few, then its likely that the disc itself is scratched or defective.
If the lens cleaner does not resolve the issue, then you will have to open the cover. Try using a can of compressed air to clean out the insides. Also, clean the lens itself with some isopropyl alcohol and a cotton swab. If the lens is scratched or dirty, you may have to replace it, in which case, it would be cheaper to simply buy a new player.
May 25, 2008 | Philips DVD 622 DVD Player
Disc read error
Could be one of several things:
  1. Disc not spinning due to bad motor or electronics.
  2. Laser not reading dues to dirty lens. Try cleaning it gently with a moistened Q-Tip.
  3. Laser assembly defective.
  4. Laser assembly not sliding on slide rail due to either bad lubrication, bad slide motor, or bad electronics.
Hope that helps....
Geno
Mar 29, 2008 | Televison & Video
TruTech PVS31170S1W 17 in. LCD Television Logo
148 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
