Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Ice clumbing into one big blob.
Ice maker works fine, then ice in the bin turns into one big blob. also have ice crystles and frosen water drops on freezer walls.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 118 Answers
You may want to check your door gasket for damage or ice build up. It doesn't sound like your freezer door is shutting properly.
Posted on Jul 25, 2009
Have replaced the 3part inlet water valve for our fridge freezer. Water is working fine,but still not making ice.
Check the ice bin level arm (also the ice maker on/off switch) is in the down position. It senses when the ice bin is full and turns off the ice maker until some ice in the bin gets used. It can also be lifted into the up position to turn the ice maker off.
Mar 07, 2017 | Westinghouse Refrigerators
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Why the ice tray does not drop the ice into the bin?
Maybe you forgot to drop the sensor bail back into the bin.
Jan 23, 2018 | LG Refrigerators
The ice maker do not give the ice
I had a problem like this it could be a few things but mine was some way or another I had a bunch of frozen ice freeze all the moving parts I had to take everything out and melt the ice it works fine now
Mar 31, 2013 | Frigidaire Refrigerators
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
No Ice From Kitchen Aid
Mark, your water valve has screwed the pooch. Replace it. The part number is 2199838.
What's happening is this... the valve that fills your ice maker is by-passing a small amount of water. This water has to flow through that tube, right? When very small amounts (drop by drop) go through the IM fill tube, they flash freeze. Eventually they (the frozen drops of water) form a big block of ice inside the fill tube. This ice creates a blockage which creates back-pressure whenever the IM "calls" for water. The back pressure eventually blows the tube off of the connection behind the fridge.
You say that this happened over night... no way. If you look closely at the ice cubes that you IM has been making, you'll see that they are hollow. Hollow cubes means that your IM isn't getting enough water... (because the fill tube is blocked).
Tracy
Mar 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
