Question about Radio Communications
Need to know purpose of 'mon' and other button on front of radio,  person who gave us 3 radios is not longer available.
  • Radio Commun... Master
  • 1,654 Answers
You do not mention the type of radio you have, so our answer will be rather generic. The "MON" button is the monitor button. It is used to temporarily shut off your interference eliminator (aka private line, PL, tone code), so you can hear if anyone else is speaking on your frequency. This is to be used as a courtesy to other radios users in your area which are on the same frequency. (Sadly, people are usually not so polite.) If your radio does not have the PL turned on, this button will do nothing, as you will already be hearing the radio traffic on your frequency.
On some models the "MON" button has both a long and a short press function, typically the short press is the temporary monitoring of the freq., while the long press is "sticky monitor" which will hold you in the monitor mode until pressed again, or the radio is turned off and then back on.
As for the other buttons, they can be programmed to a variety of options including high/low power, tight/loose squelch, scan/nuisance channel delete, battery indicator, volume set, and a few others. The only way to know for sure what it is programmed to is to have the radio readout by a dealer. Or an educated guess, as some would be obvious by their function.
Regards.
Posted on Jul 21, 2009
Cobra 29 Lx meter does not move when speaking into mic . It says transmitting but no movement stays at 3
turn you squelch all the to the left then turn your mic gain and RF gain all the way to the right. .Check the led button on the front panel and make sure it is on the setting you want it to be on then key it down .This radio is a state of the art radio and has parts that limit others from overdoing their purpose So if you cannot fix it on your own then take it to a person you know that can fix it.
Feb 07, 2017 | Cobra Radio Communications
Need factory code for radio
I had the same problem on my mercedes and i called the 800 # to mercedes and gave them my vin # and they gave me my code. So.. Its probably the same for chevrolet. It should be listed in the front of the owners manuel as long as the book goes to your vin#. good luck with that.. oh yeah u may want to find out how to enter it into your radio while u have them on the ph. unless u already know.
May 28, 2012 | 2005 Chevrolet Malibu
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
I have three walkie talkies... Motorala CLS 1110... 2 of them are on FREQ 3 and the other is on FREQ 2.... how to i change the one on FREQ 2 to FREQ 3???
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Dec 23, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How do i change the frequency and or channel
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
The instructions for getting into programming mode are on page 18. A synopsis is this:
1) Hold in the PTT button and the MON button while turning on the radio. Continue to hold them in until the radio is no longer making noise.
2) Press the Menu button one time. This is your Freq. Use the plus or minus button to change the freq. Press the menu button to lock in your selection.
3) The next number is your Code. Use the same method to select your code and lock it in.
4) Continue through the menu, making your selections according to the user guide. When you are at the end of the programming cycle the radio will emit a different chirp. When this occurs, shut of the radio and turn it back on normally. You are done programming.
Best regards.
Feb 24, 2010 | Motorola XV1100 (1 Channel) 2-Way Radio
I have a motorola t5720 and when I hit the mon key it makes no noise. I also do not have my manual. What do I do?
The monitor MON button may or may not emit noise. On some models of radios it will have "white noise" when pressed. On others it is silent. MON is used to be "polite" and see if anyone is talking before you transmit, assuming you have the interference code eliminator turned on. It temporarily shuts off your CODE. If your CODE is set to zero, you would never need the MON button, as you will hear all radio traffic anyway.
For simple operation of your radio, set all your radios identical to one another with the same frequency, code and Qt filter (if any). Use the Push-To-Talk (PTT) button to transmit, and release it when you are done talking to listen for a reply from a fellow radio user.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Oct 31, 2009 | Motorola Talkabout T5720 (7 Channels)...
CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
Mar 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
SONY ICF 2010/SONY ICF 77/AM EXTERNAL ANTENNA JACKS BAD
The antenna jack is no longer available, these can be serviced but the unit needs to be sent out. I do this service, contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2009 | Sony ICF-SW77 AM/FM/SW Radio
I need a radio code for a 2000 mitsubishi galant
Carefully take the front panel off that surrounds the radio and temperature buttons, it will snap straight out. Wiggle the radio out about two inches, it is a tight fit. Get the serial number off the radio. It is on a sticker on the top, left side. Call a Mitsubishi dealer with the serial number. They will want proof of ownership, so have the title ready. After putting in the four digit serial number, hit the cd button and that enters it.
The code is also written on an antitheft card that comes with the car and may be written in the owners manual in one of the back pages.
Jul 24, 2008 | 2000 Mitsubishi Montero Sport
Dont know what the buttons on the front of the Motorola Radius sp50.
Hello Peedi Krack,
There are two buttons on the front of the Motorola SP50.
MON - This key is a Monitor button. It temporarily disables the squelch control so you can hear any muted or weak signals being sent on the channel. This enables you to ensure the channel is clear before you transmit.
OPT - This button controls Optional functions that might be programmed into the radio, such as channel scan.
Additionally your radio might also have a DTMF keypad (similar to a telephone keypad) depending on which version of the SP50. If installed, the DTMF keypad would be used for signaling and controlling devices over the air.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 19, 2008 | Motorola Talkabout FR50 (14 Channels)...
Radio Communications Logo
103 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
