Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Carpet roller will not turn. Vacuum still sucks up dirt
The carpet roller will not turn when i use the vacuum. Vacuum still sucks up dirt, etc., but the roller/brush on the carpet head does not turn. I hit the red reset button, still did not work. What should i do?
Thanks
  • 1 more comment
  • desertthrash
    desertthrash Feb 14, 2012
    I was having this problem, and found a little white button on the bottom side, that says Brushroll Reset. I pressed this button, and I was rollin again. Didn't have to unscrew or open anything. :)
  • desertthrash
  • Anonymous Mar 26, 2014
    I was vacuuming ang got a string caught in brush. I turned off vacuum, removed thread from roller, turned vacuum back on and the brush/ roller is not moving. I pushed the button next to turn on button and still nothing
It IS true that you can take the plastic cover off the top of the carpet head. But in addition to removing the two Phillips screws at the bottom, you have to manouver the wand release a bit. Loosen the screw and carefully pull the release back just as much as you need to, to remove the cover.
You will also need to pull manually release the four clips - two at the back and two on the sides - to pull the cover off.
However, I did all this and found that the plastic setting holding the roller canister in at one end had been burned out so that the roller didn't sit properly. Nothing I can do to fix it except order a replacement. The original problem was caused by getting carpet ends caught up in the roller. This caused the burning.
Posted on Sep 28, 2009
    Problem Solver:
  • 9 Answers
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Posted on Jul 21, 2009
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Dirt devil breeze bagless height adjustment mafunction
Hi there! If your vacuum is suddenly hard to push your roller lifter assembly, which controls the automatic height adjustment, may be damaged or broken. Check your roller lifter assembly located underneath your unit for damages. Also, your brushes help to maneuver through carpet, check that your brushes are still spinning. If not, replace the belt on your vacuum. I have included a link where you may visit to purchase a replacement belt for your vacuum. Hope this helps!
Style 4
Aug 08, 2014 | Dirt Devil Featherlite Bagless Vacuum...
When i am vacuuming my carpet....it sucks the dirt up when i am pushing it forward, but when i pull it back, the dirt comes back out on the carpet
This is due to a loss of suction. The roller brush sweeps the dirt to the hose area, but with no suction, when you pull the vacuum back, the brush just kicks the dirt back out. This is most likely due to a clog in part of the hose system.
You don't mention whether it's a canister or upright, but check all hoses and tube.
It can also be due to a full bag or clogged filter. Another cause could be a fault in the switch or wiring that turns on the power nozzle (only if it has a separate motor) but not the vacuum.
The fan blades could be broken or worn, which would allow the vacuum to run, but with no airflow/suction.
Or most costly, the motor is worn out and no longer working.
Nov 03, 2010 | Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
No suction
check for clogs and maybe the brush roller is too caught up with hair and fabric from the carpet.
Mar 16, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Not picking up fuzz
I've had a similar problem with my DC07 Animal, although there WAS suction and the machine seemed in otherwise good condition, the vacuum seemed to be working normally, yet very little was vacuumed up. I would go over and over sections of carpet and get very little debris in the container. In my case, the cleaning brush roller bar was competely covered in debris (hair, dirt, string, stuffing from our chewed up dog toys, etc.). I removed the bottom cover and manually removed all this debris from the cleaner/brush roller, reattached the cover and it worked like new with great suction.
Apr 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Horrible sounds on carpet setting!
There some screws from the bottom to remove then the top cover will come off, then you can check it over to see what the problem is.
Mar 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Windtunnel U6425-900
have you tried raising the 'carpet level' adjustment?
Oct 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
536 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
