Question about Konica Minolta DiALTA Di200 Copier
Konica 7020 I have copier konica 7020 My copier giving me the error message F-26-1 i need help & i need User Guides and Repair Service for thes machin thanks
  • 1 more comment
  • Terry Anderson Aug 05, 2008
    I Have a konica 7030 that is giving a F-36-3 Code. I added toner and i still get the error code F-26-3 Can you help?
    thank you
  • Anonymous Jan 15, 2009
    My konica 7020 give me error message F-135 help me please
  • Justin Goldberg May 11, 2010
    This is from the service manual:
    F26-3: High voltage unit abnormalities.
    Causes: Abnormal output from TDS (toner density sensor) Maximum TDS output voltage failed to exceed 1.0V.
    Resulting operation: If copying is in progress, the main body stops immediately, and the main relay and 24V power turn OFF.
    Correction: Set SW2 (sub power switch) OFF and then back ON.
    Estimated abnormal parts: TDS (toner density sensor) PRDB (printer drive board) M1 (main) Developer agitating screw Developing unit connector
  • 146 Answers
F26-1 at power up. [Description] F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. bkbell@brianbell.net
Posted on Jan 03, 2008
  • 589 Answers
This was a problem in the early serial numbers on this model. The problem is the chute is clogged where the toner hopper empties into the developing unit, which has depleted the toner level. Konica did release a kit that eliminated this problem. Unfortunately, you'll have to contact a Konica dealer for the kit - if they can even get it anymore. They were relatively inexpensive if memory serves me right. You will also most likely need to replace the developer powder.
Posted on Jan 07, 2008
2 Suggested Answers
dbarchitect
  • 150 Answers
SOURCE: konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Posted on Dec 11, 2007
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7020
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Error Code F-35-6 on Konica 7020
Please call the techie, he would definetely solve the problem, because their is a risk for the rollers to be burned out
Jun 16, 2009 | Sharp AR-C160 Color Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Jul 20, 2008 | Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Konica Minolta DiALTA Di200 Copier Logo
1,504 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
