Question about Car Audio & Video
'01 PT Cruiser- when I change radio stations I loose sound- and eventually it comes back!
  • 99 Answers
If it is factory radio your radio start getting weak soon you might have no sound at all
Posted on Jul 22, 2009
Radio frequently just stops broadcasting and eventually comes back on
Peggy, Is the radio actually switching off or do you just loose the radio station. If radio is shutting off, there must be a bad wire/ plug connection, loose plug, or maybe bad ground.
If loosing station, have Arial/antenna connections checked, maybe upgrade to better antenna. Some stations just do not send out a strong signal which can also cause loss of station.
Mar 29, 2016 | 2009 Toyota Highlander
Car radio manuals
If there is a "set" button you push that first then the station button.
If not, you push and hold the station button until the sound comes back on.
Check your owners manual for details.
Sep 01, 2014 | 2001 Chrysler PT Cruiser
I CHANGED THE TIMING BELT AND SPARK PLUGS AND WHEN I DRIVE THE PT CRUISER ON THE FREEWAY IT DRIVES GOOD BUT WHEN I COME TO A STOP THE PT CRUISER RUNS BAD
Does the vehicle turn off, run rough, or hesitate?
It sounds as though you have a faulty Idle Air Control Valve".
May 10, 2012 | 2003 Chrysler PT Cruiser
I put a 2005 motor in a 2001 pt cruiser and put all the 01 sensors on the 05 motor except for the crankshaft senor it is the 05. I am not getting fire at the coil pak
your crank sensor IS what fires the coil pack
mixing the two years sounds like the problem
check wire harnes see if the 01 powers the 05 the same termail
01 senor and pack may have to go back
good luck!
Mar 01, 2012 | 2004 Chrysler PT Cruiser
Replacing the radio and was told i need a code to activate it.... If so what is the code...?
You must be replacing the radio with a stock PT cruiser radio. ( one that normally comes with the car, Not aftermarket.) recommend looking on back of radio for a radio ID number, then calling a dealer and giving them the VIN to the vehicle and the radio ID number. Once you do get the number, write it down and keep it somewhere Safe BESIDES in the car. This is a anti theft feature, so if someone steals your radio they wont be able to use it. Also if your battery every goes dead and your car looses power, you will need to re enter this number in the radio in order for it to work. ...best of luck
Jan 15, 2011 | 2002 Chrysler PT Cruiser
Weird noise from my '01 PT cruiser.
It's possible that the you have "cupped" tread on a tire or two. After rotation you may hear it. Look at the outer edges of all of the tires for an uneven tread wear. Sometimes it takes a little driving to **** this down. If no luck here, I would stop back at the garage to have them verify there isn't a safety issue.
Aug 27, 2009 | 2001 Chrysler PT Cruiser
2002 pt cruiser sunroof wont open.
sound to me that you are having a short in the dash with the radio and sun roof . check the relay see if it gets hot when you open the roof. trase the lines and make sure the two are not wired together.
Jul 13, 2009 | 2002 Chrysler PT Cruiser
Radio Station stuck on one station and wont change!
sounds like the radio is locked up.... if the radio requires a code do you have it and know how to install it... if so ... unhook the battery for about 15 minutes and hook it back up... should work ok then...
Robert
Please take a moment to rate this solution thanks
Jan 23, 2009 | 2004 Chrysler PT Cruiser
Is there any difference between '01 and '03 engine?
what you need is a Hollander book that tells you what the difference is in the engines there may be just little diff and it will tell you what you can swap .
and most salvage yard have these books and dont charge to look it up for you.
and dont let someone guess and say yes and then you have to go back and change so importaint part.
later
paul
Jan 02, 2009 | 2003 Chrysler PT Cruiser
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
