Question about LG WM-2277HW Front Load Washer
Error Message and Tub not spinning
I have a LG Tromm (WM2277HB) Front Loader Washer. It is washing and doing fine until it gets to the rinse & spin cycle. The tub will not spin which leaves clothes laying in water and shows error UE on the digtal screen.
  • 22 Answers
Depending on how many clothes are in the washer you may a unbalance error
Posted on Jul 31, 2009
    Problem Solver:
  • 18 Answers
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Posted on Jul 21, 2009
Water insufficient in LG tROMM WM2277H
There are pressure switches (weighs the tub) connect to the tub... towels and sheets hold more water and therefor weigh more.. try washing less pieces and see if that helps..
This is another example of our government knowing whats best for us!! I have to wash two or three more loads.. and THEN rinse and spin each to get them clean.. I use A LOT more water this way...
oh well...
Jul 25, 2017 | LG WM2277H Front Load Washer
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
Oe message on lg front loader washer model wm2277hb. wont drain or spin. already check the drain filter and hose. what else could be wrong
It is a long drain error and occurs when the washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Nov 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front loader LG Washer
make sure your outlet hose is not constricted or blocked in any way.
May 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,555 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
