I have a 4/ 30 capacitor and i am having a hard time finding this. can i use a 5/ 30 instead? i heard you can use a replacement that is 10% different, i'm not sure if the 5/ 30 is within this range
  • 3,361 Answers
A 5/30 will work. Check voltage on the cap 370 or 440.
Posted on Jul 21, 2009
Im getting no power whatsoever heard a pop last time i turned it on now nothing
The tv power supply board it is dead.That the board,where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering work?Yes,take ur tv aparts.Check the whole power supply board carefully,by replacing all those blown capacitors that are busted open and all those capacitors are dying going to dead like bulging up or puffing up on to it tops.Replacing all those dead capacitors to a those new capcitors,do some modification of the capacitors parts like by replacing it in the same Micro fered,but the voltages should be 5 or 10 higher than those old busted or dying bulging up tops capacitors.By replacing all these dead capacitors and dying capacitors with a higher voltages capacitors.These capacitor to have a better chances to take more heat resistance,while tv be watching for hours of using.The tv should have power and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 08, 2011 | Sharp LC-42D64U 42 in. LCD HDTV
Toshiba tv 30 inch need repair hard to turn on
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Dec 20, 2010 | Toshiba 30HF84 30" TV
Sony Wegs 42" LCD TV won't turn on, after about 30
Dec 16, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
My 26" LCD LG Tv turns on, shows the channel for
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | LG 26LC7DC 26 in. LCD HDTV
Power button blinks four times and no picture only green lines
Kaufman605
Dec 11, 2010 | Samsung SP-S4243 Television
After being off for awhile.... and then we turn it on .... the unit turns on ok ..... but after 10-30 seconds... the tv turns off..... turn it on again.... 10-30 seconds.....goes off..... after 5-7...
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
Dec 11, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Two year old LG 37LC2D won't turn on. The red light turns green and there is some movement and slight sound so it is "on", but the screen remains black. Heard this could be a fuse or something I...
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Dec 09, 2010 | LG 42LC2D 42 in. LCD HDTV
LCD TV turns itself off after I put it on. Was able to get it on again a few times and then it would stay on. Now it wont even go back on for about 30 to 40 minutes, and when it does, it goes right back...
1. Have it Repaired
Hope this Helps.
Good Luck
May 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Can putting 10w30 synthetic oil instead of 5w30
5w 30 is much thinner than 10w 30. Most newer vehicles require 5w30
I personally like synthetic oils because the viscocity adjusts with the temperature in all climates and weather. No need to change every season
Sep 09, 2009 | 2002 BMW 5 Series
Capacitor Voltage
If the 35 volts fit in the space provided for the 16 volts, is OK to use them but they must be 1000uF.
Oct 17, 2008 | Akai LCT2785TA 27 in. LCD Television
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
