Question about Freezers
Buzzer stays on; now it's defrosting. is there a reset button or something?
    Champion:
  • 363 Answers
Normally you can unplug the unit and wait five minutes and plug it back in. The default settings should appear
Posted on Jul 22, 2009
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
When I got home I heard the buzzer going off on the freezer..the temperature had dropped from -12 to -2 and I'm trying to reset it to-12 again how do you do that?
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Jun 29, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
